Author Topic: Pre-wired Pickguards  (Read 4685 times)
TheIronBeast
« on: April 30, 2009, 04:47:55 PM »
So I'm going to be ordering a set of Irish Tours at the weekend and don't know whether I'm going to just buy the set or buy them pre-wired to a pickguard. I don't have any experience with soldering and don't actually own a soldering iron. Is there any soldering involved when you buy the set with a pre wired pickguard? If there is I am probably just as well to buy the set and just get the store to put them in for me.
Re: Pre-wired Pickguards
« Reply #1 on: April 30, 2009, 05:03:17 PM »
I haven't owned a pre-wired pickguard, but I think you'd still need to solder three wires - the two wires from the jack and the grounding wire from the tremolo spring claw.
« Reply #2 on: April 30, 2009, 05:22:23 PM »
Philly's right, I ordered my ITs with a pre-wired guard (and BKP wired it how I wanted with non-standard controls at no extra charge), you still need to solder it to the jack and trem claw.
I would recommend getting a decent soldering iron (mine's 30W I think, not too expensive from Maplins) and learn how to solder. It's not that difficult to do - with a little practice, I bet you could do at least as good a job as I can! And in the long run it will save you loads of money and make you a little bit more independent... (just keep reminding yourself that one end's bluddy hot! :lol:)
Bradock PI
« Reply #3 on: April 30, 2009, 07:59:33 PM »
Can get a soldering iron from Maplins for around £5. I would always use silver solder the lead free stuff is really good now but it does need a hotter iron than previously make sure you get one for electronic joints some are structural solders. There are plenty of how to guides on the web
http://www.aaroncake.net/electronics/solder.htm
http://www.youtube.com/watch?v=BLfXXRfRIzY
