Found some cheap and pretty good (I think so, anyway!) pedals...
Started by dave_mc, May 13, 2009, 10:08:09 PM
... I thought I'd let you guys know, because I'm always very pleased when you let me know about good, cheap kit and I wanted to repay the favour. I should add that I'm not a major pedalhead, but they sound pretty good to me.
I was alerted to daphon pedals by a guy on the Tokai forum- apparently their overdrive is pretty similar to the tubescreamer. So I did the sensible thing and ordered the analogue delay and flanger instead (as they were cheaper).  :lol: Anyway, they're not too bad at all, especially considering the price (i got the delay new for £17.50, and the flanger for £22.50, all in). There's a bit of noise with the delay with the time above half-way up, kind of a high-frequency noise, which means you're limited to, I think, around 150ms, but you can get a pretty nice slapback out of it, which is fair enough for £17.50. It also self-oscillates very easily, if you're into that kind of thing. As far as I'm aware, it's analogue, but if anyone wants me to check, I can do so (assuming I can work out how to determine it's analogue- i guess i'll try to get the model of the chip and then look it up online). The flanger's not too bad either, you can get a pretty subtle tone out of it, or the jet flanger van halen unchained type thing. A little noise at extreme settings, but only at extreme (everything dimed, more or less). Again, hard to go wrong for just over £20.
My advice/personal opinion about these would be that if you would like to have an effect which you don't use too much (or aren't sure if you'll use or not) and don't want to pay too much, these would certainly fit the bill, especially if you're after a slightly more vintage-sounding, more basic effect (as I said, I think they're analogue). They're not true bypass, but the buffer seems not too bad (and true bypass affects tone too, unless you're using 3-inch leads or something). The tone quality, to me, is similar, if not even a bit better (for more vintage sounds, anyway- a little more transparent and preserves your guitar tone a little better) than your bog standard boss/digitech style pedals- put it like this, my boss tremolo is off my board, as is my digitech digital chorus, because they don't sound natural enough, and the daphons are still there. Good heavy metal cases too.
Only thing is, the ones I've seen on ebay at the moment are around the £30 mark including postage... if you're patient and can hold out for the cheaper prices I got, they're worth considering, but at £30, personally I'd save slightly more and get a Biyang, which brings me to the next bit of this thread.
I did some research on the daphons online, and came across Biyang pedals- they seemed to be reasonably well-regarded at the gear page and HC, so I took a chance. I got the od8 overdrive, fz7 fuzz, and ph8 phaser (not all at once!). A lot of their pedals seem to be clones (or close copies at least) of various "classic" pedals, but with more features, true bypass, and a cheaper price (in the UK, anyway). They seem to be decent pieces of kit- most claim to be analogue (though I should add that I've read online that their delay may be a hybrid analogue/digital design, but i haven't personally verified this either way), quite nice looking chrome/metal casing (though not just as heavy as the daphons) over what looks to be black-painted metal, and would appear to be a step-up in quality and versatility from the Daphons. While the Daphons (which I've tried, anyway) are "good for the money", the Biyangs just appear to be "good". Better than the Toneriders which Twinfan brought to our attention? Hard to say, you'd need to try the exact same pedals from each of their lineups head to head, but they have more features, certainly, and the Toneriders are half as expensive again (though I still like my Tonerider chorus a lot, it's not going anywhere anytime soon!).
The only annoying things are that the battery access is via a thumbscrew underneath (not as bad as having to get the screwdriver out as you have to with most boutique effects, but more fiddly than boss-style pedals), and they have annoying feet underneath which make it awkward to attach them to a pedalboard- and there's not really much point in removing the feet, as the thumbscrew to the battery compartment sits proud of the base too. There was also no manual, which isn't a major problem (there's info on the Biyang website), but it'd be nice to have one. They're also slightly larger than standard Boss pedals, if space on your pedalboard is an issue.
Anyway, on to the pedals. As I said, I'm not a pedalhead, and don't have the pedals which these pedals are claiming to copy to hand to do a head-to-head test, but the overdrive (in TS mode and with the jrc4558D attached) does remind me very much of the tubescreamers I've tried, except it has the added benefit of 3 switchable modes (which make a useful difference to the tone), and 3 swappable op-amps (which also make a useful difference). The fuzz, in muff mode, also reminds me very much of the (modern) big muff I've tried, and the other two modes offer a useful difference in tone too. The different modes in both pedals (and the swappable chips, in the overdrive) are definitely usable, unlike in a lot of pieces of gear where you find your favourite and stick to it. Don't get me wrong, you'd likely have a favourite mode and/or chip, but the others are usable too when you want a different type of tone. I don't know too much about phasers, but the phaser seems pretty nice too, you can get some very subtle sounds, or some very crazy (especially when combined with distortion or fuzz), but this is the one place where a manual would be handy- my ears can tell that something different is clearly happening when I change the "Intensity" switches, but it'd be nice to know exactly what's happening technically.
I'm not trying to oversell these or anything- if you already have a good vintage pedal, or modern boutique pedal, you wouldn't want to swap it for one of these (unless you wanted a completely different style of pedal- say you already have a boutique overdrive which is completely different from a Tubescreamer, but would like a Tubescreamer too). But if, like me, you're not enough of a pedalhead to want to blow £200 on a pedal, but likewise don't want to be palmed off with the cr@p that a lot of the big makes try to tell you is your only choice at the ~£40 price bracket (or more accurately, the third option, which is what I used to do until recently, just not buy anything :lol: ), then these seem to be very nice pedals indeed. You can find them on ebay (new), sometimes with the daphons you have to search for the model name rather than the brand name, and there are soundclips of the biyangs on youtube (I haven't looked for daphon clips).
Sorry for the length, but if I made it any shorter I don't think I'd be describing the pedals properly. Any questions, comments etc., please feel free :)
Here are links (they didn't do my computer any harm, but I have pretty decent antivirus software, so click at your own risk, etc. etc. ):
http://www.daphon.com/
http://www.biyang.com.cn/Prclass.asp?Id=1
Thanks for your time. :)
hermantehgerman
Sounds great Dave!
So you can only get them off of Ebay or did I get that wrong?
^ ^ did you like them or not? or did you just mean you've heard of them? :)
^ i think the company i got them off also has its own website, but it had more of the pedals on its ebay store, and was slightly cheaper too... :)
LazyNinja
Bloody hell that's a post and a half!
I've been interested in the Biyangs for a while, in particular the Delay, the Fuzz and the EQ. Does the fuzz do light, subtle fuzz as well, or is it full on mayhem like Big Muffs? I'm looking to buy a fuzz pedal that adds a fuzzy flavour to the overdriven guitar, rather than a fuzz that acts as a distortion pedal.
I had a Daphon wah wah pedal and that was a POS. The whole thing was made from cheap plastic and it got really stiff after just a couple of week's use. I've not tried the others but I wasn't encouraged by the general quality. This was 4~5 years ago so things may be diffrent now.
^ yeah, the daphon wahs looked a bit cheap, i chickened out with those. i think with the cheaper stuff like daphons, your best bet is to stick to the ones which are known to be good- and also try to get them as cheap as possible! (as i said, if you can only get them for £30, that's probably a bit much, when a biyang is only a bit more)
the fuzz seems pretty full-on. i've only really tried it so far with very low output strat single coils, and it seems pretty full on even with those. it reacts reasonably well with the guitar's volume control, but yeah. more or less full-on. the other thing is, the tone seems quite dependent on the volume and fuzz level on the pedal, too, so it can be quite muffled with those turned down low, to get a lower gain fuzz. I haven't messed with the fuzz too much yet (i've only had it, and the phaser, a few days, i've had more like a couple of weeks with the od and tried it much more), but i found myself setting the fuzz, and to a lesser extent the volume (as it seems to have a lot of volume boost available, so some of the volume setting was to get to the right volume) where i got the tone i wanted, more so than the amount of fuzz.
It's too late to read your post, but I shall post to say it is a very long post anyways. You really can talk the talk when it comes to reviewing gear Dave.
And you said you were lazy, pff.
Lew
gingataff
The Daphons are rebranded and sold under many different names, but some of the DIY guys at Freestompboxes.org think they are ok and just ripe for modding. In fact Analogman has a delay pedal specially made in the Daphon factory in China because he was impressed by their standards.
I see a rainbow rising
Look there on the horizon
And I'm coming home
Denim n Leather
Nice book, I mean review. :)
True bypass has a lot of hype. You would not want a bunch of pedals with true bypass only in your rig; would sound like ass.
hamfist
It's great to put info up like this about cheap but good gear.
THat reminds me - I got a Danelectro Cool Cat CHorus last week - £25 brand new - what a GREAT pedal, not just for the price, but simply a great chorus.  Metal case, chassis-mounted jacks and true bypass too !   Highly recommended !!
badgermark
Also check out the new Behringer stuff. Very good quality and close clones of what they are cloning.
LazyNinja
Quote from: badgermark on May 14, 2009, 07:46:51 AM
Anyone tried the deluxe memory man clone?
Regarding the Dano Cool Cat series, I heard the drive pedal uses a similar circuitry to Fulltone OCD!
tomjackson
Quote from: Denim n Leather on May 14, 2009, 03:46:18 AM
I agree but at least you know what you are getting with true bypass.  Most modern pedals with well designed buffered bypasses are great but there are still the tone suckers out there that sound awful bypassed.  I've sold at least 3 pedals because of the bypass tone (Boss SD-1, EHX micro Synth and EHX russian big muff).  Electro Harmonix have moved to pretty much all true bypass now which is a great improvement, put a decent buffered pedal at the start of your chain, even a tuner and it will overcome any mechanical losses in the true bypass switching as long as you don't have 10+ pedals and your leads are good.
But I agree it is over rated and many that claim to be true bypass aren't anyway....
Back on the subject of cheap pedals, the artec ones look pretty good value also.  I'm all BYOC at the moment though, just built the mouse and the quality is excellent, virtually no noise, even with the gain up there's hardly any hiss.
hamfist
Quote from: LazyNinja on May 14, 2009, 08:30:11 AM
In theory it is similar. I also have the Dano Cool Cat Transparent OD, which is supposed to be the same as a Timmy pedal (for those of you who know their boutiques). However, I'd say it is in the ballpark but certainly not identical at all. I'd expect the same to be of their Drive pedal.
I have been impressed with the buffers and the low noise floor on these new Dano pedals too. Unfortunately, that is usually something that Behringer fall down on, bigtime.
