Author Topic: Ageing plastic and if covers fit pickup  (Read 5414 times)
« on: May 13, 2009, 10:11:23 PM »
Bought these strat covers (white - no pole-pieces) and would like to know how long is cool for letting it age (It's alread emerged in Mustard, if don't work, will put on coffe - want it to look like these cream lace sensor)
Also does anybody know if they work on BKP strat pickups :D
thanks
EDIT: Changed the thread title because of the perverts :P :lol:
« Last Edit: May 25, 2009, 12:57:14 AM by FernandoEsteves »
Muttley
    • http://www.muttleyville.org
Re: How long?? Does it fit?
« Reply #1 on: May 14, 2009, 09:28:36 AM »
I was expecting another thread about wooden dildos...
« Reply #2 on: May 14, 2009, 10:49:33 AM »
Same!
« Reply #3 on: May 14, 2009, 12:34:28 PM »
On the first question, I don't know - I just buy covers that are already an "aged" colour.
On the second, they should fit BKPs but they won't be a good fit because the polepieces are raised quite high above the bobbin.  Maybe you could make some kind of little cardboard spacer (with 6 holes in it for the polepieces) to sit between the bobbin and the cover?
« Reply #4 on: May 14, 2009, 03:41:36 PM »
Hummm thanks Phill! I'll figure out more ahead... if you buy strat pickups let me know the height of it :D
For the two perverts: HELL NO! :P
Re: Ageing plastic and if covers fit pickup
« Reply #5 on: May 25, 2009, 12:58:14 AM »
Well, the white covers are more than one week on mustard and nothing...
Also nothing the ones on coffe, since wedsnesday, if I'm not wrong... Making a coffe now, lets see if it had to be HOT coffe :lol:
« Reply #6 on: May 25, 2009, 10:09:03 AM »
Maybe if you lightly sand the covers with some fine wet-or-dry paper, the stains might "stick" better to a rougher surface?
I also read brown shoe polish might work as a stain.  Worth a try?
« Reply #7 on: May 25, 2009, 11:51:33 AM »
I've been thinking in sanding it too, will give a try if this doesn't work (seems it won't)...
Will give a try too with the shoe polisher :D
« Reply #8 on: May 25, 2009, 12:09:15 PM »
What about soaking it in tea? Is that a method or is it just a myth?
ToneMonkey
Re: Ageing plastic and if covers fit pickup (and wooden dildos)
« Reply #9 on: May 27, 2009, 12:48:40 PM »
I've heard of the tea method before (but only for scratchpaltes).
I'd cover it in tea and yogurt and bury it in the garden for a bit.
EDIT: Although I don't know if that would work either,
« Reply #10 on: May 27, 2009, 02:13:15 PM »
I've sanded it with 1200 grit yesterday, lets see if it helps a little...
Will buy tea bags....
« Reply #11 on: May 27, 2009, 02:59:37 PM »
it does help but can highlight scratches rather than anything else - 1200 should be good
i havnt found a method i like for doing this
« Reply #12 on: May 27, 2009, 03:12:37 PM »
I'm sure I've told this one before, but one of the guitarists in Kix used to hang his guitars up in a shed with a row of burning cigarettes under them, so they'd get stained by the smoke/nicotine.
« Reply #13 on: May 27, 2009, 03:39:13 PM »
If nothing helps, I'll try HUAHAHAHAHAHA
« Reply #14 on: May 27, 2009, 04:03:41 PM »
i am not sure i would be able to stay out the shed
