Author Topic: Apartment/Flat + Guitar + Amp = Pissed?  (Read 7133 times)
Re: Apartment/Flat + Guitar + Amp = Pissed?
« Reply #15 on: May 15, 2009, 05:19:31 PM »
Let us know how you like the MJW. I have sort of been tempted to get a bigger 2x12 which would hopefully sound a bit bigger than my compact one, which I want to take to uni.
« Reply #16 on: May 15, 2009, 08:31:42 PM »
Get an attenuator. I think they make a hell of a difference. Also try and listen to your neighbors at home/out habits. Everyone has a pattern to some degree. When they're out turn it up a bit more if you feel you need to. Will's point about self conscious is very true too.
If you sit in the focus of a speaker cab it sounds a lot louder.
When we were at the jam, my amp was attenuated by 40% and it wasn't even close to full wack even with the loadbox on. Really cracked volumes with your amp without an attenuator will make you feel sick after a while.  :D You can wake the dead with a 100w valve amp. Whats the output of your VHT?
« Reply #17 on: May 15, 2009, 08:34:43 PM »
If you're serious about getting an attenuator, you should check out this:
http://www.hugeracksinc.com/forum/viewtopic.php?t=57467&highlight=
« Reply #18 on: May 15, 2009, 09:05:08 PM »
I thought Hunter was going to come in and recommend the axefx :P
I had a hotplate and it worked wonders with my fender (which had a really touchy volume control) but with my laney it didnt do anything that the master volume couldnt do. I suppose it depends if your amp gets its gain from the preamp or power amp? Would definitely try before you buy with it.
« Reply #19 on: May 15, 2009, 09:08:44 PM »
My amp seems like that but if you crank the master volume and use the channel volume I found it does make a difference.
Also Jonny an attenuator gives you some line outs for recording.
« Reply #20 on: May 15, 2009, 09:20:01 PM »
But whatever you do don't use them. They SUCK.
« Reply #21 on: May 15, 2009, 09:58:10 PM »
The ones on my Koch Loadbox don't. It has XLR balanced outputs with 4x12 or 1x12 and various mike placement sims. I've not used other makes so couldn't say.
« Reply #22 on: May 15, 2009, 09:59:32 PM »
Oh sorry I assumed you were talking about the Hot Plate.
Koch loadbox sounds cool though!
« Reply #23 on: May 15, 2009, 10:10:37 PM »
I didn't realise they weren't up to much.
So how are the studies going Indy? I wish I could do a course like your doing, reading recording sites on the net after work is a slow process! I keep loosing my audio signals for some reason.
