Author Topic: TECH INPUT ON GUITAR BUILDING INFO. DOUBT ABOUT SPECS.  (Read 4518 times)
WITH FULL DISTORTION
« on: May 15, 2009, 06:17:58 PM »
$%&#ing Hails Guys
how are yah!??!?
Hey im doing a custom guitar with Inferno Guitars australia, since we are endorses and i have my specs for my Inferno Distortion V
i would like to know if the neck specs will have any kinda of incompatibility with the rest of the guitar. specially the bridge. do i need to order a wider bridge or a different kind of bridge other than a lES PAUL/SG/v STYLE TUNE O MATIC bridge with tailpiece?
whats the differenc between a tailpiece and a stop tailpiece??
Here are the Specs
THANKS IN ADVANCE.
JP
JP - INFERNO DISTORTION V
Neck Options
Neck Wood - Mahogany .
Neck Finish/Colour – SNOW WHITE
Neck Construction - Neck Through Body.
Neck Shape Modern(back contour) - C shape,in other worlds, the same SHAPE as the Peavey Wolfgang Guitar.(Wolfgang 1st Fret - .815" 12th Fret - .940")(pleasencheck warmoth page for more details)
Headstock Style - Dimebag Horned one.pretty angles backwards 13°
Headstock and neck in one piece. If possible. Inferno Logo on the headstock.
THE ALL SEYING EYE on the top of the headstock.
Scale Length - 25'
Scale Radius - 7-1/4" Vintage Fender style.
Fretboard Wood - Ebony
Nut Width - 1-3/4" (44.45mm)
Nut Material - Bone or Graphite.
Frets - 22
Fret Sizes - Dunlop medium Jumbo - model 6105 or 6230.
Tuners 3 Left, 3 Right.
Fretboard Inlays – Zodiackal Signs from 1st to 12th Frets. As Follows -
Body Options -
Body Colour – SNOW WHITE
Body Wood - Mahogany TWO PIECES.
Pickguard in White.Gibson Style. -
Body Shape. Gibson Flying V Style.
Controls - 1 tone, 1 Volume - 3 Way Toggle Switch. Jack on top of the body/pickguard.
Re: TECH INPUT ON GUITAR BUILDING INFO. DOUBT ABOUT SPECS.
« Reply #1 on: May 15, 2009, 06:27:55 PM »
I can't answer much, but with the pickguard, you will want to choose between the larger '67 style, and the smaller '58 sizes.
I think a stop bar / tailpiece is the same thing
« Reply #2 on: May 15, 2009, 06:33:49 PM »
hails man, what measures are you talking about??
THANKS
« Reply #3 on: May 15, 2009, 06:36:45 PM »
You won't need a wider bridge unless it's a 7 string or something.
A standard tune-o-matic and (stop) tailpiece should be OK, but the saddle radius is about 10"-12".  They should be able to match the 7-1/4" radius by notching and filing the saddles.   Graph Tech saddles might be good for this, because they're a bit taller.
« Reply #4 on: May 15, 2009, 06:59:40 PM »
Hails Philly. Thanks man
hey, im sorry but i didnt understand it properly. can you explain it in another way!?!?
Q:)
JP
i understood half of it. ahahah
« Reply #5 on: May 15, 2009, 07:03:52 PM »
Hum, i think i understood it now.
so, which radius would you recomend me?
AH, i forgot to say that ill tune this guitar to B STANDARD with 013.
« Reply #6 on: May 15, 2009, 07:21:14 PM »
Was there any special reason you wanted the 7-1/4" Vintage Fender style radius on the fingerboard?
Gibsons have a 10" to 12" radius, which would match the tune-o-matic.  A lot of Metal guitars are even flatter than that.
http://www.warmoth.com/Guitar/Necks/Radius.aspx
Lew
« Reply #7 on: May 15, 2009, 08:35:57 PM »
I'd be concerned if the guy making my guitar couldn't/didn't answer it him/herself tbfh  ;p
Have you asked them?
 8)
« Last Edit: May 15, 2009, 08:37:57 PM by Lew!! »
« Reply #8 on: May 16, 2009, 03:09:28 AM »
Hails Philly its just that i had a fender copy that the fretboard, whose measurements i dont know , feels $%&#ign better to play chords in a blackmetal way : Like Mayhem on "Des Mysteriis Dom Sathanas" album. .. and i cannot play like that with the actual guitars i have
i think they are a little bit flatter.
When i do a F# Chord, its easier with that EX fender start copy than on the charvel and USA fender i have.
I Think a 25 1/2" Scale  is perfect . but i dont have an exactly clue about how rounder the radius would be to be a nice one for me. i just know that i dont like FLAT radius. not at all.
Q: (
« Reply #9 on: May 16, 2009, 03:19:36 AM »
 8)
i sent the project to him, he said no problem. NOW, i ll ask AGAIN.
q:)
JP
Zaned
« Reply #10 on: May 16, 2009, 05:36:50 AM »
 8)
q:)
JP
Might be a good time for a compound radius. If you don't know what it means, it means that the radius is smaller on the lower frets and larger (flatter) on the higher frets. Rhythm is mostly played on the lower frets, so the more curved radius is good there. And higher on the fretboard, where you play leads more than rhythm, the flatter radius is nice. If you want low action, the 7.25 inch radius is not optimal; you might 'fret out' when bending. This is because bent string catches the next fret and the note dies.
My suggestion is to go to a music store and try a bunch of guitars. Knowing what the radius is on those. Or try a PRS, almost all of them have a 10 inch radius. I have that radius on my both current electrics, and I've found it to be a very happy medium, at least for me. My upcoming guitar has a compound radius of 9.5-12..
-Zaned
Paths are for followers.
« Reply #11 on: May 16, 2009, 12:13:50 PM »
Q: (
OK JP, your USA Strat has a 9.5" radius, so if that's too flat the vintage 7.25" radius is probably best for you!
I agree with Zaned, a compound radius would be good if Inferno Guitars can build it that way.  You could have 7.25" at the nut and maybe 10" or 12" at the 22nd fret, then there wouldn't be any problem with the tune-o-matic saddles.
« Reply #12 on: May 17, 2009, 05:24:23 AM »
Hails Guys
thanks for the input
ill wait till they reply me and then, according to their rpely, ill ask, if necessary, about the compound radius. if they will be able to do it.
JP
