November 20, 2026, 10:22:54 AM
Main Menu
Main Menu
Home
Search
Bare Knuckle Pickups Forum
Forum Ringside
Tech
Technical Question About Down Tuning
Started by SRChrono, May 23, 2009, 12:52:11 AM
Previous topic
Next topic
Print
Go Down
Pages
1
User actions
SRChrono
Junior Flyweight
Logged
Hey,
I want to tune my guitar to C#, F#, B, E, G#, C#. Which I believe is drop C. I'm just wondering if I would need a neck adjustment after I did it or is it ok to tune your guitar back in forth from drop tunings to standard. Will it screw up the neck at all or anything?
Thanks
Fikealox
Featherweight
Logged
Re: Technical Question About Down Tuning
#1
May 23, 2009, 02:12:47 AM
That's C# standard, if I'm not mistaken (drop C is C, G, C, F, A, D). To answer your question, though: You can safely try it, but you'll probably need a setup to get satisfactory action.
BKPs (soon): CS, TS.
Middleweight
Logged
#2
May 23, 2009, 06:21:06 AM
What is your current tuning and string gauge?
If you up the string gauge in the right proportion, setup work can be kept to a minimum. However, you might have to have the nut slots widened to avoid tuning issues.
SRChrono
Junior Flyweight
Logged
#3
May 23, 2009, 07:58:31 AM
I'm tuned to standard with 11s - 46 on the guitar.
pagan7
Bantamweight
Logged
#4
May 23, 2009, 10:49:09 PM
You may also need to tweak the intonations for an "in tune" drop tuning all the way up the neck
Middleweight
London & Southeast's Number 1 BKP stockist
Logged
#5
May 24, 2009, 12:48:20 AM
You WILL need bigger strings 11-54 minimum I would say
You will need a nut adjustment , and an intonation adjustment
You may need a truss rod adjustment too
syr2012
Featherweight
Logged
#6
May 24, 2009, 03:02:34 AM
You might be fine if you only do it once in a while and not for long. But if you plan on doing some serious playing, you're gonna need to have all that feline mentioned adjusted. I used to do Db every now and then, but never seriously enough to mandate adjustment.
SRChrono
Junior Flyweight
Logged
#7
May 24, 2009, 06:18:21 AM
Thanks a lot for the replys guys! I'll consider the change on one of my guitars :D
Print
Go Up
Pages
1
User actions
Forum Ringside
Tech
User actions
Print
