Author Topic: Buying replacement tubes, whats all the testing about?  (Read 1895 times)
Catalyst77
« on: May 26, 2009, 08:48:42 PM »
Ive been looking to buy some nos pre-amp tubes both 12ax7 and 12ay7 of ebay, and come across tubes that tested 66 or 98.
Does anyone know what this means?
And what a good test rating would be?
Cheers :)
jpfamps
    • http://www.jpfamps.com
Re: Buying replacement tubes, whats all the testing about?
« Reply #1 on: May 26, 2009, 08:58:46 PM »
The pre-amp valve ratings are largely meaningless as they don't seem use any defined parameters — every vendor seems to use a different "rating" scale.
Most of the of them seem to be some sort of "gain" rating, which are done with the pre-amp valve in fixed bias, so this really doesn't have much to do with a cathode biased pre-amp valve in a real amp.
The gain of many stages in valve amps are determined predoninantly by the passive components and not the valve itself, and regardless I'm not sure if you could hear a 5% increase in gain in any stage one stage.
The main concern regarding pre-amp valves is that they aren't excessively noisy or microphonic, so this is worth testing for although, obviously, there is no standard as to what is "acceptable".
