November 22, 2026, 01:23:20 AM
Main Menu
Main Menu
Home
Search
Bare Knuckle Pickups Forum
Forum Ringside
Pickups
Which Pups please?
Which Pups please?
Started by limeypip, June 01, 2009, 01:16:38 AM
Previous topic
Next topic
Print
Go Down
Pages
1
User actions
limeypip
Strawweight
Logged
Which Pups please?
Last Edit
: June 01, 2009, 05:47:07 PM by limeypip
Hi all,
I own two sx 24" scale, strat style guitars. Their nut width and scale lenghth suit me just fine. They're cheap but they have been set up properly and the're not too bad at all.
I'm haveing one converted to have a three way selector switch and two humbuckers. I love the thin lizzy sound but I also like the modern santana sound. I've had some advise from Tim but I'd like to have a few more opinions. Which set of bkn pups would you recomend or would you recomend a combination? I only play at home and my amp is a marshall mg15dfx.
Both guitars have rosewood boards. One has an ash body. The other has alder, which one would you convert to get the best tone suited for humbuckers?
Regards and steady as you go ---- Phil
syr2012
Featherweight
Logged
Re: Which Pups please?
#1
June 01, 2009, 09:45:09 AM
Phil, Tim wouldn't steer you wrong. If you like Santana's sound, I think Abraxas would do the trick. As for converting your strats, what would you use the remaining guitar for?
limeypip
Strawweight
Logged
#2
June 01, 2009, 05:44:28 PM
Hi,
Thanks for the reply. Yes I do trust Tim's judgment. I thought it might be of interest to read other peoples views and to see how many came up with the same choice. The slight doubt I have is that all the sound samples I've found so far, with these pups, feature heavy metal music. I'm not into this at all.
I'm only coverting one guitar. The other I'll keep as it is. I may get some Irish Tours for them but I can't see that happening for quite some time.
Steady as you go ---- Phil
P. S. You'll never see Rory live again so here is the next best thing
www.sinnerboy.co.uk
Denim n Leather
Guest
Logged
#3
June 01, 2009, 06:02:11 PM
What woods? Amp? Thanks!
syr2012
Featherweight
Logged
#4
June 01, 2009, 06:09:25 PM
In that case, I would probably convert the ash guitar if you want the strat with ITs to keep that stratty sound. Plus, ash might work better with an abraxas, since it has a bit more of a pop than alder. Otherwise, it's really whatever you wish.
limeypip
Strawweight
Logged
#5
June 02, 2009, 09:03:11 PM
Thanks fror the advice. It makes good sense. I was thinking the ash one simply because fitted with a couple of camos, it will look superb.
Print
Go Up
Pages
1
User actions
Forum Ringside
Pickups
Which Pups please?
User actions
Print
