Author Topic: GSP1101 high gain tones - your opinions please !  (Read 3893 times)
hamfist
« on: June 08, 2009, 02:16:50 PM »
I seem to be getting the best tones out of my GSP1101 when running it through an EL34 amp and into a guitar cabinet, but also I want to develop some good patches for recording direct too.
 Here's three high gain patches I've been working on this afternoon for recording direct into the computer. I have a definate favourite. In contrast, I also think one of them sounds rather artificial. I'd be interested in people's thoughts  .... also about the amount of high end. I have a tendency to make my high gain tones rather too bright. I don't think I have here, but would like some confirmation.
1/ 5150 patch - http://www.box.net/shared/static/3agegkydd4.mp3
2/ SLO patch - http://www.box.net/shared/static/z920jo1pnj.mp3
3/ Dual Rec patch - http://www.box.net/shared/static/rso2f0cqh3.mp3
Re: GSP1101 high gain tones - your opinions please !
« Reply #1 on: June 08, 2009, 02:26:31 PM »
the 5150 sounds a bit muffled, or i would prefer that. got to go with the dual rec then :)
« Reply #2 on: June 08, 2009, 02:27:58 PM »
I liked the 5150 (through my laptop speakers that is). The SLO sounds "further away" than the other two. The Rec is lacking the crunch I like on the 5150.
Maybe 5150 with a tad of scoop in the mids?
viking
« Reply #3 on: June 08, 2009, 02:56:27 PM »
I have very bad speakers...but,i agree with the others  :)!To have the "chuga-chuga",it must be between 5150 and the Recto.I prefer the 5150 (even if he is a bit muffled indeed) because it stays "clean" with his crunch  :?  PS:SLO is not doing it.
« Last Edit: June 08, 2009, 02:58:13 PM by viking »
hamfist
« Reply #4 on: June 08, 2009, 03:12:44 PM »
OK, It seems I over-compensated with rolling off the high end. Here's my second attempts, taking your comments into consideration !
I have to say, I think the 5150 is in a class of it's own.
5150 - http://www.box.net/shared/static/k4frsr2ckf.mp3
SLO - http://www.box.net/shared/static/use09j71hm.mp3
Dual Rec - http://www.box.net/shared/static/vdsx6n86rh.mp3
« Reply #5 on: June 08, 2009, 03:21:50 PM »
+1
Sounds as if it would come from a different, better unit.
dheim
  • DON'TPANIC!
« Reply #6 on: June 09, 2009, 05:40:49 PM »
5150 is the best, even if it still sounds quite digital to me. and i'm a pod user! :)
too many? ;)
« Reply #7 on: June 09, 2009, 05:44:23 PM »
defo 5150
« Reply #8 on: June 09, 2009, 05:46:46 PM »
I think SLO is my favourite. They all sound pretty good for direct though.
How much are these GSP1101s?
  • Truly bad since 1972
« Reply #9 on: June 09, 2009, 06:10:19 PM »
out of the three the 5150.....but maybe a little tweak to brighten..for me
« Reply #10 on: June 09, 2009, 06:20:29 PM »
£384.50 at Digital Village _tom_ - quite well priced
« Reply #11 on: June 09, 2009, 06:35:20 PM »
5150 sounds best - it's the low mids.  Sounds like you've EQ'd a boost around 200Hz-400Hz ???
hamfist
« Reply #12 on: June 10, 2009, 06:50:56 AM »
I haven't EQ'ed that, but it seems to be a combination of that particular amp and cab model together.
 The 5150 amp model doesn't sound anywhere near as good through any other cab model in the GSP. Similarly, I don't love that particular cab model with other amp models.
hamfist
« Reply #13 on: June 10, 2009, 06:55:01 AM »
Exactly the same tones from the RP500 though (£219 from GAK), just a little less functionality than the Rack-mounted GSP.
« Reply #14 on: June 10, 2009, 11:29:58 AM »
good tip! that thing /looks/ cheap and low end though.! digitech need to work on their styling. if they sound good now, they should stop looking so plastic-fantastic.
« Last Edit: June 10, 2009, 11:38:39 AM by gwEm »
