Main Menu
Amp problem
Started by TomW, June 17, 2009, 10:59:46 AM
If it doesn't say anything on the amp (or in the manual -Marshall site) it should normally be a slo blo.
While ordering, get a few spares for each of your fuses, throw them in the guitar case and always take them with you. Why are so many people gigging without spare fuses?
jpfamps
Quote from: TomW on June 19, 2009, 02:55:23 PM
Haha cheers for adding all this info everyone, learn so much off this forum. However I've got abit of a n00b question now, as I'm struggling to find which fuse to get. The fuse that has blown says Lf.T2AE250V on it, therefore would the 2amp time delay fuse on this website: http://www.maplin.co.uk/Module.aspx?ModuleNo=452 be the correct one to get? Or is it a quickblow fuse I need?
T2A is indeed a 2 A time delay, or SLO BLO fuse.
GL62S on the Maplin web page web page will be the correct one to get (assuming that you want a 20 mm length fuse).
TomW
Well I've just replaced the fuse and it seems to be working fine now, but i've only had about 5 mins to play it, so I'm gonna take the amp to band practice tomorow and test it out properly. All the tubes look to be fine with none of them glowing brighter than the others or anything so hopefully everything is ok.
Riff Raff/Stormy Monday, Holydiver and Mississippi Queen!!!
www.myspace.com/therealamorist
hamfist
Quote from: TomW on June 20, 2009, 10:31:14 PM
Fingers crossed then !!
