Wich fuse?
Probably a power tube. When have you last retubed/biased the amp?
Or maybe a tube has rattled lose on transport?
Replace fuse, warm up, switch on. If it doesn't blow, check the output tubes, is one of them red at the bottom? That is called redplating and it means you should replace the set.
You can also take a pen and tick all tubes and see if there is ringing noise through the amp, also an indicator.
