Author Topic: New Painkiller "Problem"  (Read 3216 times)
musicmaker29
« on: June 19, 2009, 01:26:32 PM »
Hi guys,
I bought a PK neck pickup and just had it installed the other day, I love the power that my guitar now has and I like the responsiveness of the pickup, but I just have one issue with it and that is that it 'quack's (the only way that I can describe it!).
I guess it may be because its so middy, but is there anything I can do to reduce this aspect of the sound, it just sounds very very harsh at the moment because of it - I have an eq pedal (mxr), and I think I need to cut some mids, but what would you change in my situation? (pup height, tone, volume, eq......) I play hi-gain metal stuff and the unwanted tones sound worst on clean, still present on distortion but doesn't sound as bad.
it also squeals a lot, but I think that a noise surpressor might sort that!
Thanks very much,
Alex
Re: New Painkiller "Problem"
« Reply #1 on: June 20, 2009, 12:26:13 AM »
"Quacks" sounds like an odd description of a humbucker. You couldn't have wired it out of phase could you?
Nolly
  • Global Moderator
« Reply #2 on: June 20, 2009, 12:52:20 AM »
That's odd, the PK neck is almost scooped sounding. I trust you have bought a specific neck pickup, not a PK bridge and put it in the neck?
syr2012
« Reply #3 on: June 20, 2009, 07:39:00 AM »
It sounds like it's out of phase. It's also possible that there's only one coil wired instead of both. You should definitely take a look at the wiring.
m0jo
« Reply #4 on: June 22, 2009, 12:40:51 PM »
Does it hum more than a humbucker should? Because this would indicate either one coil or out of phase wiring like syr2012 says.
Their shouldn't be any squeals at all though.. maybe something wrong with the pickup although I find it hard to believe..
MXG custom '60s fiesta red strat
Ibanez S470DXQM
-->shiteload of pedals-->
Laney VC100
dheim
  • DON'TPANIC!
« Reply #5 on: June 22, 2009, 01:33:36 PM »
i'd try to install it again... i don't know if PK's peculiar mid response can be described as a "quack", and i'm not sure if the squealing you hear comes just from improved presence and attack (then you should change something in your EQ)... does it happen even on low strings?
too many? ;)
« Reply #6 on: June 22, 2009, 04:17:33 PM »
my holy diver squeals a lot, specially with the drums
it's extremely sensitive
my friend's pk squealed too, but he got it rewaxed
syr2012
« Reply #7 on: June 23, 2009, 03:43:27 PM »
I don't think it's normal for your holydiver to squeal, the only time mine ever did so was in a situation where I was running too much distortion through an amp that wasn't really made to handle that in the first place.
How's your pickup height?
« Reply #8 on: June 23, 2009, 06:44:39 PM »
it always squealed at any height in all the 3 guitars I had it installed
specially with boosters
and I always a lot of mids and highs
but it's extremely sensitive to any kind of vibration or interference by itself
