miracle man specs...
Started by dheim, June 27, 2009, 03:16:52 PM
dheim
i lost the tech sheet of my MM set... what are their DCR readings? bridge is ceramic and neck is A5, right?
too many? ;)
gingataff
Mine says;
Bridge 17.8k ceramic, Neck 17.5k A5.
I see a rainbow rising
Look there on the horizon
And I'm coming home
dheim
gosh! i didn't remember how hot actually is the neck MM...
thanks a lot!
too many? ;)
syr2012
Quote from: Will on June 27, 2009, 09:07:13 PM
Mine were both 17.5
How's the volume difference between bridge and neck?
Perfect, they are completely different pickups, it really does make the middle position great with more options playing around with Vol and Tone controls, but it actually still has a similar element to the ZW EMG middle position. Very versatile.
Remeber: DC resistance is not the same as output, the MM set is a great example of this.
juansolo
[url="http://stompage.juansolo.co.uk"]http://stompage.juansolo.co.uk[/url]
Alex
If mine comes out as 15, does that mean my meter is broken?
dheim
Quote from: Alex on June 28, 2009, 09:19:04 AM
there's supposed to be some variability, but this is A BIG difference...
anyway i'd say that if you like your tone you shouldn't care about numbers!
too many? ;)
