Author Topic: small powered pedal boards  (Read 3392 times)
« on: July 14, 2009, 01:17:53 AM »
anyone use smaller powered pedal boards for something like a wah and 3 or 4 boss sized FX.
i always have bad luck with noise when powering FX from mains outlets. but id like to move to a powered pedal board as long as the power is hum free-ish or whatever.#
any ideas?
Zaned
Re: small powered pedal boards
« Reply #1 on: July 14, 2009, 06:43:55 AM »
Sounds like you want the power outlet to be built-in on the pedalboard. That was one option for me too, when I was building my board. However, they were not easy to come by here and I ended up ordering a separate board and a separate power, namely the Voodoo Lab Pedal Power II Plus. Isolated outputs and the works, I have only good things to say about it. Noiseless and can give power to almost any pedal.
If you combine that with something like a T-Rex ToneTrunk (http://www.t-rex-engineering.com/Default.aspx?ID=95), you can do whatever you like.
And then the boards with built-in power one example: http://www.furmansound.com/product.php?id=SPB-8
Whatever you end up buying, I strongly recommend that you pay attention if the power outlets are isolated. Ground loops are not nice, and I believe that they occur much more easier if you combine pre-amp effects and effects in the loop from the same power. Unless the outputs are isolated of course. But I have a gut feeling that you're not gonna  bother with fx loop (which I have my delay on), so isolated outputs might not be a definitive requirement.
My 0.02 euros.
-Zaned
« Last Edit: July 14, 2009, 06:46:10 AM by Zaned »
Paths are for followers.
sjwebb90
« Reply #2 on: July 14, 2009, 05:07:14 PM »
Make sure you get yourself a regulated Power Supply.
I use one of these from Maplin Electronics, more than enough to power most pedals and it doesn't hum
http://www.maplin.co.uk/Module.aspx?ModuleNo=32754
Daisy Chain lead
http://www.maplin.co.uk/module.aspx?moduleno=1410
Cheers
SJ
  • Truly bad since 1972
« Reply #3 on: July 14, 2009, 05:43:09 PM »
I use the johnny pedalfreak ones..think a few others do on here..no noise
badgermark
  • Mm-hai!
« Reply #4 on: July 14, 2009, 05:53:48 PM »
Same, i use the JSF one too. Reliable and pretty small, no problems running all of my home made pedals.
« Reply #5 on: July 14, 2009, 06:35:39 PM »
I run homemade and general make ones no problems with noise..even at dodgy practice rooms
