Neck BKP humbucker
Started by LMCollard, July 21, 2009, 12:13:54 PM
LMCollard
Hi all. I've a problem : I have a strat with 3 beautiful Trilogy suite pickups :D, but I recently took the decision to put
a humbucker in neck position... the problem is that I dont really know which one choose : painkiller, cold sweat, MM (i heard it was the "best" with the Trilogy's), nailbomb, warpig... There are too many choices  :( . So I ask you which one should i get ( i like Pantera, Megadeth, Metallica, Iron Maiden, Thin Lizzy, Joe Satriani, Steve Vai, Dream Theater... sorry its very large  :?)
Thank You, BKP roxx!  :D
BKP -
Trilogy Suite kit, Crawler kit, HolyDiver bridge humbucker
kevinr
In the neck position! I would think that it will over power the singles! I would be asking Tim on this one.
guitardude
even with the high output of the Trilogy suites i think all of the humbuckers you named would be over powering
Antag
#3
Yeah, are you sure you meant to type "neck" position? Single coil bridge & middle + Humbucker neck seems a very odd pickup configuration...
Assuming that you actually meant "Bridge" position for a standard HSS config, & that your strat has an alder body, I'd say Holy Diver - balances great with Trilogy mid/neck, sounds fantastic in alder & covers all the musical ground you want.
So, please confirm which position you're putting the humbucker in & what your strat is made of... :)
EDIT: Perhaps a picture would be helpful here.  This is what we mean by a standard HSS pickup config:
Antag
& welcome to the forum BTW...
syr2012
The MM would definitely work well with the trilogy set if it were in the bridge, but would definitely be entirely too overpowering in the neck. If you are interested in a neck humbucker, maybe a VHII?
LMCollard
Ok i understood, i thought the humbucker must be placed in neck pos .
So if it was in bridge position, the MM is the best for me ?
BKP -
kevinr
Nailbomb should fit in well I would think, great bridge pickup.
Antag
Like I said earlier, it all depends on what woods your guitar is made of.
Assuming alder or ash, I'd say NB would be a far better choice than MM.  I had an MM bridge in my alder strat (in fact, that's it in the pic above :)) & it was OK, but the NB I swapped in there is a far better match for that guitar.  But I still stand by my earlier comment that the Holy Diver is a great match for Trilogy mid/neck, sounds wonderful in alder & covers all the musical requirements you listed.... :)
Perhaps we should approach this a bit differently:  What is it about the Trilogy bridge that makes you want to replace it?  What do you want more/less of?  What doesn't it do for you?
LMCollard
In full distortion, i trained a lot to be clean with those pickup, but it's always dirty ! so i thought (for solo's rather i remind), changing the trilogy neck for a NB or MM was a good choice, but if it's better to change the bridge Pickup..  :)
I have an alder strat-like.
(Excuse me for the spelling, im french)
BKP -
LMCollard
Oh my god, i made a little mistake  :D, i mixed up bridge and neck position, yeah i want to put a humbucker in BRIDGE position  :)
BKP -
syr2012
If the guitar is alder, then definitely Holy Diver. Nailbomb's a close second, and the MM would most likely be too shrill.
Antag
#12
Bienvenue au forum de BKP :)
J'ai pensé que vous avez voulu dire "bridge" plutôt que le "neck" :)
Tellement encore je dis "Holy Diver" ou peut-être "Nailbomb".  Vous avez besoin de "midrange" en alder et le HD est plus souple que MM.
S'il vous plait excuser mon français - je suis pars l'école plus vingt ans :)
LMCollard
#13
I didnt know the selection of the pickups depended so much of the wood :o
I dont like Dio, but if its the best pickups... in fact i cant play with the sound of the artists
i quoted if i cant put the right humbucker because of the body's wood
( excuse me if im not clear)
good french ^^ btw.
BKP -
LMCollard
#14
Is there a topic for the "correspondance" between woods and pickups in this forum ?
BKP -
