Author Topic: need help choosing pickups  (Read 5182 times)
guitardude
« on: July 21, 2009, 05:45:33 PM »
i need help choosing a pickup. my guitar has an alder body with maple neck and rosewood fretboard. i am looking to replace the bridge humbucker. i am looking for warm low end and fat highs and mids. i mainly play hard  rock like van halen and ozzy. i hope you guys can help?
syr2012
Re: need help choosing pickups
« Reply #1 on: July 21, 2009, 05:53:27 PM »
Maybe a VHII or Black Dogs?
guitardude
« Reply #2 on: July 21, 2009, 05:56:36 PM »
looking around on this forum i seen some people say the VHII was on the bright side. is that true?
guitardude
« Reply #3 on: July 21, 2009, 09:08:29 PM »
i dont often like really high output pickups but what about the HolyDiver and Nailbomb?
IntenseJim
« Reply #4 on: July 21, 2009, 09:59:57 PM »
IMHO a tad brighter than a PAF or Black Dog (which I looooooove) but I'd describe it as more 'open' sounding with stronger mids.
...to my ears.
Just straight line it !
syr2012
« Reply #5 on: July 22, 2009, 12:04:51 AM »
I have a Holydiver, it's quite warm and middy, and very thick. I think the nailbomb's a bit sweeter, but both should be able to amply cover your needs. The Diver, however, is known to be at home in alder, though, so I'd suggest that.
guitardude
« Reply #6 on: July 22, 2009, 01:00:21 AM »
at second look with the HolyDiver what is all the stuff about transparent highs? not sure that is what i want as for i am looking fat highs.
guitardude
« Reply #7 on: July 22, 2009, 01:06:04 AM »
i looking for something along the lines of dare i say a dimarzio super distortion but a less output and better. will the holydiver be like that?
syr2012
« Reply #8 on: July 22, 2009, 02:13:58 AM »
It'll definitely be better than the super distortion and since it's AV instead of ceramic, it's most likely a bit cooler and the cleans will definitely be much, much better.
kevinr
« Reply #9 on: July 22, 2009, 12:36:44 PM »
I have both Holydivers and Nailbombs, and I would say without doubt that the highs are thicker and sweeter with the Nailbombs.
LMCollard
« Reply #10 on: July 22, 2009, 03:15:07 PM »
If you like the current ozzy sound ( so with Zakk Wylde ), the MM is far away better, with a sound like EMG's
but for "cleaner distortion" like van halen, i can't help you and i let the pros answer you
BKP -
Trilogy Suite kit, Crawler kit, HolyDiver bridge humbucker
syr2012
« Reply #11 on: July 22, 2009, 03:26:46 PM »
Unless your guitar is dark, stay away from the MM. It would be entirely too bright and may make you miserable. If you want a ceramic, consider a cold sweat or painkiller, though the cleans on the latter are not very clean.
LMCollard
« Reply #12 on: July 22, 2009, 03:32:57 PM »
Yes, i heard some CS, they are f****** amazing :p
BKP -
« Reply #13 on: July 23, 2009, 12:25:53 AM »
the cold sweat is brighter than the miracle man
the miracle man has a higher treble peak in the high strings, but it's not brighter than the cs
syr2012
« Reply #14 on: July 23, 2009, 12:59:14 AM »
I thought the painkiller was the brightest, then the miracle man... Well, my mistake. I think the only way for me to provide an accurate evaluation of the ceramic line is to TRY THEM ALL! If only my wallet allowed...
