Author Topic: proper vintage fender waxed cloth push-back wire  (Read 3969 times)
« on: July 22, 2009, 01:47:13 PM »
after messing around soldering cheap thin wires, and surface mount devices in my work.. this stuff is an absolute joy to work with! really easy to make everything neat and tidy. easy to solder, stiff and easy to route, push the cloth covering easily in each direction.. my days it must have been great to work with it all the time in old times!
just wanted to share my feelings with the BKP community :)
Re: proper vintage fender waxed cloth push-back wire
« Reply #1 on: July 22, 2009, 02:40:58 PM »
Ha ha - I agree!  It's great stuff!
5F6-A
« Reply #2 on: July 22, 2009, 09:06:36 PM »
correct
I use it 90% of the times for my wirings
"I now consider atheism to be brutal because it offers neither consolation nor liberty of any kind" Benjamin Constant in 1804
"Practice until you can hear the metronome grooving" Carol Kaye
Oli
« Reply #3 on: July 23, 2009, 12:17:41 AM »
It's the only wire to work with! :)
Prawnik
« Reply #4 on: July 23, 2009, 03:13:45 PM »
The irony is, I thought it was the biggest pain to work woth until I figured out the "pushback" bit.
durrr...
« Reply #5 on: July 23, 2009, 03:51:35 PM »
durrr...
I have to confess, I still haven't figured that out....
I try to cut it - which never gets through all the fibres - and it goes all tatty and unravelled at the ends.
If you "push it back" doesn't it just slide back into place again?
« Reply #6 on: July 23, 2009, 04:02:00 PM »
well for a start you need to cut it with something sharper... but not all cloth covered wires are created equal
i had some yellow and black stuff from axesrus that frayed as soon as it was cut and ended up looking a little messy.  The proper stuff doesnt fray much at all. it does slide back into place a bit after pushing back, but not too much.
bucketshred
  • Groovy
« Reply #7 on: July 23, 2009, 05:17:02 PM »
Geeks. :p
GREAT GOOGILY MOOGILY!
« Reply #8 on: July 25, 2009, 12:31:15 PM »
I buy the Stewart MacDonald's stuff and it is great.  It comes in 3 colours (black, white and yellow) and so is good for keeping wires easily recognisable.   I also use their screened wire too.
gingataff
  • NBVHIIMMPKAHITTSSH
    • My YouTube Channel
« Reply #9 on: July 25, 2009, 12:38:11 PM »
I have some Fralin wire but it's non-waxed.
I've also got some vintage Belden stuff that looks like cloth covered wire (cuz it is) but has a plastic insulation layer between the wire and the cloth. Great quality but really tough to strip.
I see a rainbow rising
Look there on the horizon
And I'm coming home
« Reply #10 on: July 25, 2009, 05:15:48 PM »
I ordered cloth-covered wire from a couple of places and wasn't impressed with it.  Also it's damn expensive - I'd rather buy PTFC wire if I'm gonna spend the extra.
Prawnik
« Reply #11 on: July 25, 2009, 06:40:09 PM »
I am trying to find cloth-covered wire in green and orange (often seen in late 1960's Fenders; apparently they were using wire left over from the amplifier division).
jpfamps
    • http://www.jpfamps.com
« Reply #12 on: July 28, 2009, 06:24:39 PM »
The Mojotone wire is pretty close. By the way I would call it yellow rather than orange....
I tend now to only use the cloth covered wire for repairs on vintage amps.
As stated about it's quite expensive. Also, I now try to avoid using solid core wire
yellowv
« Reply #13 on: July 28, 2009, 07:10:38 PM »
Yeah I soldered some of the Fralin cloth clovered wire the other day. Man it was a breeze.
Prawnik
« Reply #14 on: July 29, 2009, 09:45:14 AM »
Thanks! I am seriously GASsing for one of their ampli-kits. I suppose I could justify it if I really need to order some wire (to save on shipping costs).
