Author Topic: 2006 SG TOM replacement  (Read 6662 times)
Snikch
« on: July 23, 2009, 04:14:01 PM »
I'm planning on replacing the TOM bridge on my riff raff equipped Gibson SG Standard with a callaham model
http://www.callahamguitars.com/abr1.htm
what i need to know is do i need the ABR-1 style posts or the Nashville conversion posts?
and can any of you knowledgeable chaps point me in the direction of a good aluminium tailpiece?
Thanks  :D
Re: 2006 SG TOM replacement
« Reply #1 on: July 23, 2009, 04:32:52 PM »
A Gotoh tailpiece will do you well  ;)
I think you'll want a Nashville conversion post as your guitar will have a Nashville bridge as stock.
« Reply #2 on: July 23, 2009, 04:42:35 PM »
You need to look at the way the bridge is attached to the body.  The ABR-1 posts are made of threaded rod, screwed straight into the wood of the body:
The Nashville bridge is a bit wider (from front to back) and doesn't have a wire holding down the saddles.   The posts screw into metal bushings pressed into the body:
On a 2006 SG Standard I think it'll probably be a Nashville bridge.
For an aluminium tailpiece, you can't go wrong with Gotoh:
http://www.wdmusic.co.uk/product/STOP_TAILPIECE-_ALUMINUM_WITH_NICKEL_PLATE_GE101ZNA
That's a nickel one, but you can also get them in chrome and other finishes, there are usually some on eBay (at cheaper prices too).  If you want a locking version, there's TonePros, but they're modified Gotoh parts anyway:
http://www.wdmusic.co.uk/product/TonePros_Standard_Tailpiece_Aluminum_-_Chrome_T1ZSA-C
« Reply #3 on: July 23, 2009, 06:04:21 PM »
You're better off with a Nashville style bridge.
Every ABR-1 bridge will start to rattle sooner or later.
Snikch
« Reply #4 on: July 23, 2009, 09:37:47 PM »
Thanks for all the info gents.
I installed a Callaham bridge into my Strat last year and the improvement in tone was considerable, so hopefully the combination of the ABR-1 and aluminium tail piece will have a similarly positive effect on the SG.
Now to look into some caps.  :)
