Author Topic: Stupid wiring question of the day - aka HELP!  (Read 1814 times)
Lew
« on: July 29, 2009, 06:34:13 PM »
I'm fitting some mid 70s greenbacks (thanks Ian/HTH!) to my Martamp 2x12".
2x16'ohm = 8ohm
I've got 4 cables, 2 red and 2 black. I know that  2 red go to the positive and 2 blacks go to the negative of one speaker because that's how Martin wired it... but then... it would seem that 1 black and 1 red go off to the neg/pos of the other speaker and the other black and red go off to the jack (Martin has wired the 2 jacks together)? Does it matters which pair of black and reds go to the speaker and which to the jack? Or am I waaaaaaay off?
Bear in mind I'm a complete wiring noob!!
Ta!
Re: Stupid wiring question of the day - aka HELP!
« Reply #1 on: July 29, 2009, 07:41:29 PM »
You need it in series:
Jack positive to positive of first speaker - red cable
Negative of first speaker to positive of second speaker - red or black cable
Negative of second sepaker to jack negative - black cable
Not sure why you had 4 cables, as you only need 3????
Lew
« Reply #2 on: July 29, 2009, 09:12:23 PM »
aha the way you described its sounds fantasticly simple! Cheer Dave  8)
No idea about the 4 cables but they were all wired up somehow
Edits: how do I know which is the pos and which is the neg lug of the jack or does it not matter?
Are you sure it's series I need not parallel? It's parallel going by this site http://colomar.com/Shavano/2x12wiring.html it would make sense with the 4 cables too?
 2 - 16 ohm speakers = 8 ohms ?
« Last Edit: July 29, 2009, 09:29:14 PM by Lew!! »
« Reply #3 on: July 29, 2009, 10:03:22 PM »
Sorry mate - I gave you series for two 8ohm speakers to give a 16ohm load.  Read the post too quick.
You need parallel - ignore me!
Lew
« Reply #4 on: July 29, 2009, 11:25:58 PM »
hehe no worries - all working now.
When Ian/HTH says something sounds good he means it, these speakers are $%&#ing great, it's like night and day against the old speakers!
