Rebel Yell bridge pick up problem
Started by duke_maiden, August 05, 2009, 12:20:26 PM
duke_maiden
Hi there, I am having trouble finding a fault on my guitar and just wondered if anyone could shed some wisdom on tis.
I have an epiphone les paul with a set of rebel yells in. The bridge pickup buzzes especially when I touch the pickup cover. I took the back plate off to look at the pots for dry joints etc and everything appears fine. However the buzzing stops/greatly reduces when I touch the wood in the back cavity of the guitar. Thsi has me very confused as I cannot see a wiring fault or earth grounding problem.
any help much appreciated. Duke
Quote from: duke_maiden on August 05, 2009, 12:20:26 PM
what you are hearing is definately a grounding problem so check again.
badgermark
The back cavity is most likely covered in shielding paint, when you touch it you are grounding the whole thing and the buzz goes away. Like Wesley says, check your grounding! Back of pots, bridge and jack socket all need grounded.
