Author Topic: Death metally riff ( sort of ) - Nailbombs  (Read 12698 times)
lepersmeesa
« on: November 01, 2005, 05:48:11 PM »
Alot of people ask if the Nailbomb has enough behind it to do more extreme music. I hope this clip helps a little in that department, however awful the mix is ! I will try and get another mix done as soon as possible.
Cheers
Dez
Recording Setup,
MBox, PODXT, Ibanez RGT2020 w/nailbombs H H
I am Ted Theodore Logan...
www.myspace.com/thesafetyfire
« Reply #1 on: November 01, 2005, 10:12:29 PM »
hey that was awesome - i have no worries that nailbombs won't be heavy enough for me, i love how they seem so smooooth, and brutal at the same time!!! Thanks man, rock on  :twisted:
steve
    • http://www.cdbaby.com/stevegladman
« Reply #2 on: November 01, 2005, 10:30:55 PM »
Wicked playing man!And great Nailbomb tone.
HJM
« Reply #3 on: November 02, 2005, 07:11:33 AM »
Excellent....love the riff and teh bass drum crushed my head :twisted:
lepersmeesa
« Reply #4 on: November 02, 2005, 12:34:03 PM »
Cheers guy, much appreciated.
HJM, you said you had DFH, have you found a way for the kick drum to really stick out cus i find that mine hasnt got enough presence. Any help would be appreciated.
HJM
« Reply #5 on: November 02, 2005, 12:55:23 PM »
Have you played with the different beater options?
I tend to do a fair amount of work on the Kick using compression and EQ, a touch of low mid cut and add som hi mid for click usually works. Don't go mad boosting bass either, it makes matters worse!! :lol:
lepersmeesa
« Reply #6 on: November 02, 2005, 01:44:48 PM »
Yeah i general cut mids, boost hi's and boost 75hz and below. Works on sub woofers and big speakers, but makes everything else sound like ass. Im gonna have to have another go at the bass drum. Sounds great through my good speakers, and then over to a pc....absolute poopshnapp.
I have tried the all the beaters and find felt no wires is my favourite. I think i need to update my samples, i remeber going onto the website when i got DFD ( if you havent got it, go get it )
Ill have a go at what you said. Are you cutting the frequencies from around 200hz-1khz? Quite a wide and shallow?
Cheers for the tips.
HJM
« Reply #7 on: November 02, 2005, 02:38:44 PM »
That's wide and shallow, I'm always a little careful of low boost around 75hz, had a listen to it on some Genelecs an that's definatly not helping....sometimes boosting narrow around 100-120 gives a bass boost effect, as heard on car stereos everywhere....
lepersmeesa
« Reply #8 on: November 02, 2005, 04:51:17 PM »
cheers for the tips. Hopefully the next thing i post will have a better bass drum!
