Author Topic: Fender vs Squire Strat  (Read 6536 times)
« on: August 11, 2009, 12:55:30 PM »
Does anyone know if there's a difference between the body of a Fender and a Squire strat?  Are the dimensions the same, etc?
Mark.
Re: Fender vs Squire Strat
« Reply #1 on: August 11, 2009, 01:03:36 PM »
They should be the same if it's one of the decent Squiers.
Some of the really cheap Indonesian (or are they Indian?) Squiers look a bit "off", though.  I suspect the manufacturing tolerances aren't too tight either.
I'm not sure if US plastic parts and hardware will fit a Squier exactly, though - a few screw holes may not quite line up.
« Reply #2 on: August 11, 2009, 02:05:42 PM »
That sounds pretty good - screw holes I can deal with.
My reasoning is that it's easier to pick up a Squire body on Ebay than a Fender one.
What about "Starcasters"?  Are they completely different?
« Reply #3 on: August 11, 2009, 02:32:31 PM »
I'm assuming you mean one of these:
And not one of these  :D :
They're real bargain-basement jobs.  Ply body probably, but maybe multi-piece alder or something.
http://www.fender.com/starcaster/
« Reply #4 on: August 11, 2009, 03:37:42 PM »
Yeah, that's them.  Best avoided, I guess - Ebay is full of them...
Cheers, PQ.
« Reply #5 on: August 11, 2009, 05:43:51 PM »
Watch some of the Squier Strat bodies Mark - they're thinner than Fender ones.  In particular the Squire Affinity ones definitely are.  Knackers you up when you put a nice chunky trem on one and it sticks out of the back....
« Reply #6 on: August 11, 2009, 05:48:50 PM »
Good point, Dave.
Unfortunately, you never know what you're buying...  for £20 or so it might be worth taking a punt.
« Reply #7 on: August 11, 2009, 05:54:57 PM »
Good point, Dave.
Just ask them to measure the thickness of the body - wants to be 44-46mm thick
Less than 43mm is too thin
« Reply #8 on: August 11, 2009, 06:07:25 PM »
STEER WELL CLEAR OF THE STRAT-ALIKE STARCASTERS!!!!
They are meant to be cheaper made than even Squiers for Walmart in the US.
