Author Topic: Tubes, mods, or EQ?  (Read 7804 times)
donbarzini
Tubes, mods, or EQ?
« on: November 02, 2005, 01:35:30 PM »
Just out of curiousity, how many people use EQ's with their amps? I have a JCM800 4104 combo that I waiting to get back from having a tube buffered FX loop installed. I've read that some people use EQ's in their loops even though my only purpose for the loop was to get my H&K Replex delay after the gain stage. Since I love to mess around with the searching for the "ultimate tone" I recently picked up an MXR 10 band EQ based on the positive reviews I have read on the unit. I'm thinking that an EQ will let me fine tune the frequencies and from what I understand, most mods, not gain mods, really just fine tune the EQ. I also understand that some tubes are brighter, some darker, so I would think that an EQ can adjust that as well. FWIW, I've been using JJ's, EL34L's and ECC83's from a company called Eurotubes. I'm looking forward to getting my amp back and messing around with the MXR.
HJM
Tubes, mods, or EQ?
« Reply #1 on: November 02, 2005, 02:43:14 PM »
Your theory is right, just in practice the less you have tends to sound better....so if you can fine tune your amp with valves (JJs I find brighter than most) mods, speakers etc your tone will benefit from more clarity. (this is coming from a bloke with more pedals than he can use!!)
If you think about it, there's overdrive, but everything else that makes us identify a certain amp over another is down to EQ.....but don't tell me you can EQ a JCM800 to sound like a Dual Rec! :lol:
donbarzini
Tubes, mods, or EQ?
« Reply #2 on: November 02, 2005, 03:00:39 PM »
Thanks HJM,
I really like the stock tone of the JCM800 with my Maxon OD-9, however, there is always just a slight bit of room for improvement. I really want to stay away from mods (besides the FX loop) so that is why I decided to get the EQ. I also just picked up that Maxon OD-9, I really like it and it has replaced my modded OD pedals.
HJM
Tubes, mods, or EQ?
« Reply #3 on: November 02, 2005, 03:58:21 PM »
I've got an Analogman modded Maxon OD9 - it's on the Nailbomb BKP demo track. Great pedal!
Tubes, mods, or EQ?
« Reply #4 on: November 02, 2005, 04:40:35 PM »
Quote from: HJM
Guitar: HJM's RG550
Amp:JCM800 50watt-stock
Effects: TS9 overdrive
it says yu used a TS9??? I guess they're based on the same sound, but still, grrrrrr
willo
Tubes, mods, or EQ?
« Reply #5 on: November 02, 2005, 04:54:39 PM »
does it really matter? :roll:
HJM
Tubes, mods, or EQ?
« Reply #6 on: November 02, 2005, 05:08:15 PM »
It was my Maxon/Analogman OD9 Silver mod.....basically a TS9!
donbarzini
Tubes, mods, or EQ?
« Reply #7 on: November 02, 2005, 05:49:43 PM »
I never tried an Analogman modded pedal except for the YJM308/250 pedal which I really didn't care for. I have a Keeley TS-9 and SD-1 but I think that the mods add a distinct artifical buzz that is especially noticeable during soloing. I do not notice this with the stock OD-9. This may not be noticeable to clean/blues players with lower gain Fender type amps. Could it be that some mods can make a pedal too hi-fi, especially for higher gain players?
HJM
Tubes, mods, or EQ?
« Reply #8 on: November 02, 2005, 06:26:51 PM »
I've found that too with the Keeley SD1. The Maxon mod is better, but I really like the MXR Wylde OD (I didn't want to like it...) and the HBE Big D.
donbarzini
Tubes, mods, or EQ?
« Reply #9 on: November 02, 2005, 07:32:39 PM »
HJM,
I've heard that the Zakk MXR is really good, my buddy brought it up just the other day in fact. I'm the same way, usually I do not like the "Signature Artist" merchandise but I may have to give this Zakk pedal a try.
Bogner
Tubes, mods, or EQ?
« Reply #10 on: November 05, 2005, 01:35:30 AM »
I tried it and wasn't incredibly impressed with the Wylde drive pedal.  I thought the SD-1 was as good if not better and the tubescreamer was better to my ears that the Wylde drive pedal.  Keep in mind I have the Zakk Wylde signature stack.  My old JCM 800 heads sounded better than his signature 2203 IMO.  I loved the 2205 and 2210 heads the best.
With all great rewards come potentially greater risks...Dare to believe.
