Author Topic: elusive guitar bits!  (Read 1975 times)
andi.j
« on: August 17, 2009, 01:40:11 PM »
 I've called round a couple of stores and custom shops with little luck other than to find out they're looking for the same stuff!
I'm trying to track down some of the foam/rubber padding that sits in the trem route on the front of the guitar to prevent the trem from dameging the body when un-strung...
if anyone can point me in the right direction I'd appreciate it - the custom's on hold till i find something!
thanks
Re: elusive guitar bits!
« Reply #1 on: August 17, 2009, 01:43:17 PM »
So...you want some foam, basically.
Improvise. I'd start by trying a (suitably carved up) mousemat.
andi.j
« Reply #2 on: August 17, 2009, 01:48:09 PM »
...yeah, that'd probably work... (insert embarrassed smiley!)
i'll go back to my cave like a good neanderthal
ta!
« Reply #3 on: August 17, 2009, 01:49:34 PM »
;) Quite welcome
I figure its the same basic stuff. You want a dense rubbery foam; theres loads of it about, it doesnt have to be guitar specific :)
« Reply #4 on: August 17, 2009, 01:53:46 PM »
as long as the finish on a guitar you want to use it on won't react to the rubber right?
« Reply #5 on: August 17, 2009, 01:54:59 PM »
Good point. Some will some wont. Might be tricky to find out.
andi.j
« Reply #6 on: August 17, 2009, 02:04:17 PM »
well, the top coat is polishe polyurethane (sp?) so i guess it'll be a bit of trial and error
cheers
ToneMonkey
« Reply #7 on: August 17, 2009, 02:35:16 PM »
I thought people just slipped a bit of card down there when restringing?  Am I talking about the right bit?
