Author Topic: Painkillers for my 1980 Les Paul!  (Read 10346 times)
orchid
« on: August 24, 2009, 07:08:45 PM »
Hi!
I'm new on this forum...I discovered the BK recently and i'm very impressed. I want to change the pickups of my 1980 Gibson LP Custom to get more powerfull, agressive but beautiful and sweet tone, with great clean sound too (it's very important!!). My tunning is DROP C
The reference bands may be:
http://www.myspace.com/cultofluna
http://www.myspace.com/explosionsinthesky
http://www.myspace.com/mastodon
Tim has said that the Painkillers are the best for me. I trust him, but i want a BK's user opinion. That's why i'm writing this post.
So...what do you think?? What about the Cold Sweat or the VHII?
Thanks!
« Last Edit: August 24, 2009, 07:10:24 PM by orchid »
Re: Painkillers for my 1980 Les Paul!
« Reply #1 on: August 24, 2009, 08:16:43 PM »
well, I have a 1970-1972 custom with a nailbomb set
sounds aggressive enough me
I also have a 1990 japanese LP copy with a cold sweat set, and it sounds somewhat similar, but the bridge pup is a bit brighter and crunchier, and the neck pup is smoother and middier
but the painkiller will work pretty well too, just like all the contemporary other models and some of the low output models
those bands play a lot of clean parts, so I'd stay alnico
99_not_out
  • RT Ponting, b Swann
« Reply #2 on: August 24, 2009, 08:41:33 PM »
I have a PK bridge in a PRS Singlecut, and its certainly (oh yes) powerful, agressive with (when played that way) a beautiful and sweet tone ... under gain. The clean sound is good, but not "great" IMHO, but then I do have wired straight to the Jack :shock:
Do you play your cleans off the neck mainly? The PK bridge is definitely what you want for those under-gain tight aggressive drop tunings, and you could consider another, Alnico, neck pickup to go with it? A Cold sweat neck maybe.
The PK neck is ceramic I think (I don't have one) so perhaps is a little less sweet on the clean channel than some of the other choices out there, but like I say I don't actually have one :(
« Last Edit: August 24, 2009, 08:43:25 PM by 99_not_out »
orchid
« Reply #3 on: August 24, 2009, 08:49:22 PM »
Ok, so you recommend Nailbomb, am i right??
Tim said that Painkillers have a good clean tone too...but i think the Painkiller could be a very "metal" pickup for me. I don't play things like Megadeath or Lamb Of God...
But my tunning is DROP C (C-G-C-F-A-D) and people say that the PK works perfectly with the DROP tunings!
Nailbomb or Painkiller??
P.D.: if BareKnuckle had only one pickup it would be easier hehehehe
orchid
« Reply #4 on: August 24, 2009, 09:06:57 PM »
I play a lot of cleans, a lot, so i need a good and bright clean tone. But the Hi-Gain Sound and Palm Mutes are very important to me too... I play with a Mesa Boogie Dual Rectifier and i'm considering to buy a VHT Pittbull
Another reference: http://www.youtube.com/watch?v=D_W3G7KmPkw   (listen at 2:00 for full clean)
About the position...well, i play cleans in both positions (neck and bridge). Maybe i play more in the bridge because i love the bridge's bright (the neck pickup sounds deeper)
« Last Edit: August 24, 2009, 09:13:35 PM by orchid »
99_not_out
« Reply #5 on: August 24, 2009, 09:37:02 PM »
If you want tight downtuned palm mutes with a Dual Rec, listen to Tim - definitely the PK!
The PK bridge would give cleans close to that track (like it BTW) too - don't get me wrong, it cleans up well - just not as sweet as a lower output humbucker. But that is the age old condundrum when playing metal-with-clean-bits :)
I can try and do you a clip if you like? Might have to wait till Wednesday though.
« Reply #6 on: August 24, 2009, 10:18:32 PM »
well, the Nailbomb is much tighter than I expected too (just as tight as the Cold Sweat)
at least in my les paul
but now I gotta add that the Rectos work better with ceramics, so now I'll agree with the Painkiller advice, or maybe a ceramic bomb
orchid
« Reply #7 on: August 25, 2009, 11:40:11 AM »
People say that Nailbomb is more versatile than Painkiller, and that's very important to me. I like tight palm mutes but i play palm mutes the 10-20% of the time. The most important part are the cleans, playing some solos, arpegios and tappings, and the distorted chords (with 3, 4 and FIVE notes simultaneously!!) that's why i need clarity too. In addition, we play a lot of parts with distorsion + effects like reverb, delay on the first strings...
So...NB or PK??   :o
« Last Edit: August 25, 2009, 11:45:25 AM by orchid »
99_not_out
« Reply #8 on: August 25, 2009, 01:54:12 PM »
In a U-turn, based on your last post I'm going with the Cold Sweat now.
Lower output that the PK, the CS is versatile and very good for the cleans, playing some solos, arpegios and tappings part, whilst still being tight for those palm mutes. Nearly bought one instead of my Painkiller, but I was after aggressive as my no.1 factor and not cleans.
Let the amp do the heavy lifting for the aggression, your amps are more than capable I believe :)
The CS will also give you the brighter clean tone you are after, and the neck pickup is superb for smooth leads and clarity while shredding (and is Alnico V to the bridge's Ceramic).
orchid
« Reply #9 on: August 25, 2009, 05:06:30 PM »
Thanks! I'll consider your CS recomendation...
But...why not a Nailbomb?? This pickup seems to be used for a lot of styles like rock, heavy, metal, progressive...and for a lot of guitars. My guitar's last owner say that i've to buy a NB...
My last talk with Tim:
"I need a versatile pickup, with agressive (like the other link - isis) and sweet sound (like explosionsinthesky), friendly with the drop tunning. I am thinking in Nailbomb or Cold Sweat, because the people says that the Painkiller are very "metal" and not versatile. "
And Tim say:
"From an '80 LPC Painkiller is definitely the right choice and cleans are really good too."
Very difficult decission!! Do i have to trust the user or the manufacturer?? hehehehe
lulusg
« Reply #10 on: August 25, 2009, 05:17:59 PM »
It's a Win.. Win situation! It won't be your first set I predict!
Just passing by
99_not_out
« Reply #11 on: August 25, 2009, 05:47:24 PM »
Go with what Tim said, its rule No.1 round here anyway!
Tim is probably the No.1 user as well as the manufacturer, he plays all his products - which is why they are so good :)
sebby123
« Reply #12 on: August 25, 2009, 08:02:51 PM »
Does your Other LP have a rosewood fertboard the comparison between ebony and rosewood will tighten up the low end some more then rosewood and have a slight more compressed feel then rosewood as it has a more "open sound" That might have helped also the Super thick maple cap. Not that i dont believe the nailbomb is as tight in the low end! Just saying that might have a huge part :D
orchid
« Reply #13 on: August 26, 2009, 10:35:24 AM »
Well, i've asked in other forums...and the 80% people say "NAILBOMB"...so due to popular demand i'll buy NB!
Maybe the PK would be ok too, but i think Tim is not considering my "versatile" requisites
« Last Edit: August 26, 2009, 10:36:58 AM by orchid »
MrPring
« Reply #14 on: August 26, 2009, 01:09:00 PM »
If Tim says Painkiller then get a Painkiller.
He knows the pickups inside out (funnily enough).
I still dont understand why people write threads like this.
Email Tim, then buy what he recommends. Simple.
“You can't arrest me, I'm a rock star" Sid Vicious
Blackguard Flat 50s, Rebel Yells and P Bass.
