Author Topic: Where to buy 3DPDT switches from?  (Read 6668 times)
Brow
« on: November 04, 2005, 06:20:53 PM »
Hey guys.
I've started experiencing problems with my wah pedal and the guy that modified it for me has recommended that the 1st thing I try is a new switch before I send it back to him so he can check it out.
The current switch in the wah has 9 contacts on the bottom and is a 3dpdt switch (?) Does anyone know where I can buy these switches from?
I've checked Allparts, WD Music Products and Maplins and they don't appear to have them  :?
Thanx for any info anyone can offer.
Craig
big steve
« Reply #1 on: November 04, 2005, 06:47:06 PM »
3pdt= 3 pole double throw
i'm assuming your wah has an in-use LED? otherwise, you'll only need a DPDT swich (double pole, double throw) which are easier to come by.
if you need the 3pdt, i think i've seen a few being sold new on ebay. good luck.....
Brow
« Reply #2 on: November 04, 2005, 06:50:39 PM »
Quote from: big steve
Hi Steve :)
My Wah doesn't have an LED, it has True Bypass, and external Volume and 'Q'control (neither of which need the 3PDT I assume).
The current switch has 9 terminals on the bottom, so i was told to just look for a switch that had the 9 terminals on the bottom and to use that :)
Whether this si correct or not, I don't know  :roll:  :?
willo
« Reply #3 on: November 04, 2005, 07:03:31 PM »
Electro Harmonix 3PDT switches (true bypass) here:
http://www.hotroxuk.com/store/erol.html
You need to scroll down to Guitar Effects, then Electro Harmonix and its in there.
Is this what you are after?
Brow
« Reply #4 on: November 04, 2005, 07:16:22 PM »
Quote from: willo
Yup, that appears to be what I'm after, thanx  :)
« Reply #5 on: November 05, 2005, 12:46:58 AM »
you can also get them at the following website if you fancy supporting a small business (his wahs sound awesome, I have one)... http://www.wah-wah.co.uk/
 :twisted:
