low output for high gain
Started by CJ, September 05, 2009, 10:04:34 PM
CJ
just looking into some pickups for my beautiful Dean Z that some of you may have seen.  :lol:  what i want is a low output pickup that's going to be heavy as hell. i'm going to be running this guitar through my Engl E530, and i've found out from my miracle man and over-wound warpig, that hot pickups into a hot amp isn't the best choice. i'm going to try out a low output pickup this time and see how it goes. i'm not really sure what i want here... i guess my best description would be a low output warpig type pickup. basically just something that will be very heavy when run through a high gain amp. heavy palm-muting, good pinch harmonics, etc.
my first though are black dog's... but what do you guys think?
oh, and i'm not sure which pickups can get which covers, but a battleworn/beaten black pickup cover is a must
thanks fellas.
Wait...did you say overwound warpig?
W
T
F
CJ
Quote from: MDV on September 05, 2009, 10:09:18 PM
W
T
F
didn't you have an overwound Miracle Man?
and yes, i did say i have an overwound warpig  :D tim made me one that would be a bit more similar to the ceramic warpig, but still with an alnico magnet.
Ah, one sees. Yeah, its 23k, kieran has it now.
If you go too low I recon you lose the thunk in the low end and the highs get too sharp and tinny. Subject to tuning, guage and EQing of course. Stick in PK/NB territory and you should be happy.
low gain in Dean Z? maybe i would try riff raffs looking at the posts here
CJ
thanks guys. i just want to try something different. i think i also recall tim having great results with mules going high-gain. i also remember a little while back i was asking tim about a pickup for my ML. i was wanting to get an jon schaffer type tone, real tight and heavy. he suggested a black dog since i was using a high gain amp.
Quote from: gwEm on September 05, 2009, 10:42:18 PM
+1
Quote from: CJ on September 05, 2009, 10:45:50 PM
I'd say BD too, if you had a les paul for that
Alex
I have a Black Dog as well now and I would also say it's what you should get.
CJ
thanks guys. how about the lesser mentioned vintage hot pickups? emerald, abraxas? i wouldn't mind having a real unique tone. i figure anything can get heavy if its played through the Engl. as long as it can get some good harmonics and some chunk to it.
nfe
Riff Raff in an LP Custom:
www.myspace.com/chronocide
I'd say you should err on the side of the higher output pickups in the Vintage Hot range (you can always put the over-wound WP back in there and drop the pre-amp gain, if you don't like it ;) ). Black Dog certainly springs to mind, but bear in mind that this is based on my own experience, and I have a phat baritone with huge strings. With that said, I've dropped the preamp gain on my 5150 from about 7/10 where I used to have it with a MM-loaded ibanez (also in A-E-A-D-F#-B but with 13 gauge strings), and not it's on about 3-4/10 with my black-dog loaded vociferator (baritone, same tuning as above, 14 gauge strings). Work that one out! :D
Roo
I have a similar problem. The Crawlers in my Yamaha SG are too hot for my Engl Classic Tube's liking.
They're fantastic pickups, they just don't get along with that amp.
I second the Riff Raff suggestions.  Let the amp do all the work  :)
Quote from: Twinfan on September 07, 2009, 11:13:55 AM
Same here.
I must admit though, Riff Raffs and Mules are the only BKP humbuckers I have personal experience of though :lol:. I use my Riff Raffed guitar for my own "metal" (old skool) musings... To me they seem to take whatever I throw at them gain-wise, they're very "clear" and "compact", and can end up sounding quite "modern" to my old ears :D
