Author Topic: Is it really worth making a Standard Crybaby true bypass?  (Read 3519 times)
everton_fc
    • Guitar Jar
« on: September 13, 2009, 08:53:41 AM »
Hi - Is it really worth making a Standard Crybaby true bypass? Do they really suck lots of tone or do you need to Eric Johnson to notice it?
Any experience or advice would be great on this subject,
Cheers
LazyNinja
Re: Is it really worth making a Standard Crybaby true bypass?
« Reply #1 on: September 13, 2009, 09:14:10 AM »
No, you don't have to be Eric Johnson to notice it. It's pretty obvious the difference when I have my crybaby from hell in the chain. I assume the bypass on the standard crybaby will be the same or worse than the Dime wah. I always have it on my board so I stopped caring though.
Spitfire
« Reply #2 on: September 13, 2009, 09:33:40 AM »
yes it is worth doing. also try swapping out some of the resistors to improve the sweep.. i got rid of the strange muffle sound mine had when it went even slightly heel.  I took out the buffer too, which seems to have dropped the volume slightly.
Fender Telecaster
Jackson KV-4
Starfield SVA-1
« Reply #3 on: September 13, 2009, 01:28:09 PM »
^ +1
wahs are the biggest tone suckers out there when bypassed - true bypass that sucker!!!
LazyNinja
« Reply #4 on: September 13, 2009, 05:11:37 PM »
How easy is the mod to do?
« Reply #5 on: September 13, 2009, 05:47:50 PM »
do a search for 'true bypass wah', its a piece of piss.
  • Truly bad since 1972
« Reply #6 on: September 13, 2009, 05:48:12 PM »
think if you search there is a blow by blow video online
sjwebb90
« Reply #7 on: September 13, 2009, 07:24:46 PM »
Check out Tonepads offboard wiring pdf.
http://www.tonepad.com/getFileInfo.asp?id=76
If you use "offboard wiring 5" with the 3PDT switch you can install an LED to show when the wah is on and off.
« Reply #8 on: September 13, 2009, 09:19:50 PM »
depends on the quality of the rest of your signal chain (including leads), but yeah, it's noticeable.
everton_fc
    • Guitar Jar
« Reply #9 on: September 14, 2009, 01:42:30 PM »
OK cool, thanks.
Problem I got is I suck with a soldering iron. Anyone recommend someone, in the UK I could send my pedal to make it True Bypass?
Plexi Ken
