Does anybody on the board repair pedals?
Started by Lu_B, September 17, 2009, 11:23:00 AM
Lu_B
LED has gone on my carbon copy and I'm not experienced enough to change it
Spitfire
if its only a simple swap the LED most ppl with a soldering iron should beable to do it.. including me, but.. i have little experience so i woudnt want to waste your time if for whatever reason i couldnt do it.
Fender Telecaster
Jackson KV-4
Starfield SVA-1
The biggest deal about it is that is seems like nothing, but could still take 30 mins plus to do depending on whether you need to disassemble part of the pedal.  Most techs, me included, would do it for the basic 1st-hour bench charge (around £30.00).  You might be just as well off getting a mate with a soldering iron to do it.
My biggest concern would be HOW and WHY the led has stopped working - its highly unlikely to have worn out, so that leaves the explanation as a wire coming loose or the pedal has been run with an incorrect power source.
