Author Topic: Curious About Hand Care  (Read 3676 times)
Tone_Freek_Lurch
« on: September 19, 2009, 03:22:31 AM »
Hey. I am a player from the states. I've been playing guitar for almost a decade, and I have a problem. When I play, the fingers on my left hand occasionally lock up on me and take a second to pop out of whatever posission they locked up in. My little and ring fingers are the worst. I do have incredibly long fingers. I'm starting to get worried about this getting worse and my performance as a guitarist compromised. Guitar is my life and I need to be the best I can be. Please any thoughts on how I can prevent this, or any thoughts on making my fingers more dexterous. I do well but always need improvement. Thanks
~Lurch
Re: Curious About Hand Care
« Reply #1 on: September 19, 2009, 07:49:16 AM »
~Lurch
Try taking cod liver oil regularly
« Reply #2 on: September 19, 2009, 08:09:24 AM »
Don't worry too much. I get something similar and I would say rest your hand (if you are not gigging!) and leave it for a few minutes-maybe make your playing sessions shorter in duration. As Johnny said, cod liver oil for the joints is good and if I am at home I put my hands in warm , not hot, water for a short while but don't play as it softens the skin.At a giig it is more of an issue and I usually tell the guys to do a song that I don't have too much to do on to give my hand a break.
JDC
« Reply #3 on: September 19, 2009, 04:02:07 PM »
you do any stretching before you play? not sure if it helps but worth a try
Tone_Freek_Lurch
« Reply #4 on: September 19, 2009, 05:42:40 PM »
Thank you for your help! I will definitely look into that and see if I can get my hand working a bit better! very useful information!
CJ
« Reply #5 on: September 19, 2009, 06:32:22 PM »
that happens to me a lot with my pinky. although, i don't recall it happening once i recently started doing better warmups before playing. more importantly, i did more warmups which focused on doing wide finger stretches. seems to help a good bit.
« Reply #6 on: September 19, 2009, 07:23:37 PM »
I've had joint issues my whole life... Particularly knees and hands. Tried everything and physiotherapy.
The best thing I've ever used is high strength Glucosmine Sulphate - no pain whatsoever now. Good luck.
« Reply #7 on: September 19, 2009, 07:29:59 PM »
The old peoples around here have a lot of cod liver oil and glucosmine suphate for joint issues. Seems to help them, may do you some good!
ToneMonkey
« Reply #8 on: September 23, 2009, 09:57:45 AM »
Me too, but I light them up anyway  :lol:
I have a problem with my index finger on my left hand which means that a lot of the time I can't even press down the top on a can of deodorant.  Sometimes I hit it on my steering wheel which hurts like a right bar-steward.
Can't see me able to be playing after I'm 50 or so, so I might take up slide  :D
