Author Topic: Amp problems, advice needed!  (Read 7149 times)
Brow
« on: November 08, 2005, 12:13:18 AM »
Hey guys.
I was at band practise earlier and while I was playing, my Marshall JTM60 combo just cut out. The mains power was still there, it just lost all sound.
I looked around the back and 1 of what I believe to be the power valves was glowing immensely (more than the other power valves) and was extremely hot. So I turned the amp off, unplugged it and left it alone.
I've noticed over the last week or so that my 60w valve combo has had trouble keeping up with the other guys Peavey Bandit or 40w Marshall valvestate combos, so I figured it was maybe ready for a new set of valves.
Does this sound like a symptom of being a valve problem? If not, what could it be and what should I do about the amp?
Thanx for any info.
Craig
« Reply #1 on: November 08, 2005, 01:02:05 AM »
Sounds like a blown power  tube, B+ fuse, or both.
HJM
« Reply #2 on: November 08, 2005, 07:35:21 AM »
Try new valves, but with caution, could be lots of things. I prefer brining an amp up with a variac after this sort of problem. Then you can monitor all the voltages. Marshall bias supplies can cause this problem too.
Brow
« Reply #3 on: November 08, 2005, 09:12:16 AM »
Thanx for the posts guys :)
I'll just find a local competent tech and let him sort it out I think :)
Craig
chrisola
« Reply #4 on: November 08, 2005, 11:08:33 AM »
buy my JCM800, it has some spare power tubes :P :P
« Reply #5 on: November 08, 2005, 01:00:16 PM »
It's probably the tubes. When you've changed the tubes and rebiased the amp, keep an eye on the tubes. If the same problem occurs it's your output transformer.
Brow
« Reply #6 on: November 08, 2005, 05:59:05 PM »
I'm going to buya  pair of power valves myself (so i know how much they cost) and just get a tech to fit them and look the amp over to make sure everything else is ok.
If that fails, I'll just have to make due until I cana fford another amp to replace it.
Quote from: chrisola
I already have 1, but the spare power valves would be handy  :D
