Author Topic: Pickup suggestions for Organic Classic  (Read 3796 times)
Stu
« on: October 04, 2009, 07:36:42 PM »
Hi,
I've got a left handed Organic Classic (Paduak body and neck, maple top and ebony board) and want a pickup change. As it was the first lefty Duncan made it has a JB in the bridge and Jazz neck.
I'm looking for a bridge pickup with a more full sound as the JB sounds thin. I quite like the jazz but would like both pickups to be slightly hotter. I'm going for a modern rock sound with warm articulate and harmonic tones. I play through a Vox AC15 heritage and use a T-rex Mud honey for OD sounds.
I may contact Duncan direct as I understand he now sells his guitars with Custom wound BKP's but wanted to get some suggestions on here first.
I'm aiming for this to compliment my new Gus G1 which is in the Strat ballpark and is especially good for blues and funk so the organic would ideally be for straight out rock.
Cheers!
Stu
Re: Pickup suggestions for Organic Classic
« Reply #1 on: December 14, 2009, 10:44:25 PM »
Any suggestions?
Thanks
syr2012
« Reply #2 on: December 14, 2009, 10:53:36 PM »
Holy Diver?
Or is that too hot?
Nolly
  • Global Moderator
« Reply #3 on: December 15, 2009, 12:33:29 AM »
Maybe Nailbombs? They're labelled as part of the "contemporary" range, but they're quite classically voiced, very open and dynamic pickups. They can, of course, bring the heavies when you need them :)
If they sounds a little too metal, maybe consider the Rebel Yells, which are in a similar ballpark to the Nailbomb in voicing, but not as hot, with a tad more vintage toothiness.
Also, the Crawlers could be worth a thought as well - extra-hot PAF tone, with a smooth high end and very fat midrange.
BigB
  • Let's rock !
« Reply #4 on: December 15, 2009, 09:13:02 AM »
The Crawlers are indeed pretty good for everything rock - from 60s to more contemporary tones. Have them on an all-maple Vox (very bright and tight),  the bridge is sharp and cutting, yet still warm, ringing cleans, grinding rythm and riffs with some OD - and man, it has the power to push your amp into serious overdrive -, and singing and warms lead under heavier distortion. The neck is much more rounded, absolutely wonderful in cleans (can even do jazz) and slight OD (think Beano), and very smooth and sustaining when pushing the amp. Both are _very_ articulate, even with higher gain settings you still hear each individual note.
HTH
Stu
« Reply #5 on: December 15, 2009, 07:01:33 PM »
Thanks for the suggestions.
Sounds like if I want out and out rock then maybe the Nailbombs would be good. I'm not really looking to use it for metal but definitely hard rock.
  • Brokeback is back
« Reply #6 on: December 15, 2009, 07:38:14 PM »
I got a nailbomb bridge in my LP and like you I don't play any metal, but a great varity of rock. The nailbomb suits hard rock nicely, but I find it too agressive for more classic rock. Might just be me though. I think (without having played any of the following) that the Rebel Yell, Crawler or maybe Abraxas could be good options opposed to the Nailbomb.
« Reply #7 on: December 16, 2009, 11:38:16 AM »
full, warm and articulated = holy diver
+1
nailbomb is VERY aggressive for an alnico pup
loud, punchy and very focused and dense tone
not really warm, imo
rebel yell won't sound fatter than a JB
pop
« Reply #8 on: December 16, 2009, 12:08:27 PM »
...sorry wrong tread...
bridge: NB, CS, C-WP, TM
neck: NB, TM, MQ
Stu
« Reply #9 on: December 21, 2009, 11:09:14 PM »
Thanks for your input.
I've been looking at clips of those suggested but its hard to compare when you haven't got them in the same guitar. I'm looking to play anything ranging from Zeppelin to Satriani. If any one has heard an Organic with BKP's in then it would be great to hear your views.
My main issue is that the JB in the bridge position always sounds a bit thin and brittle.
Stu
« Reply #10 on: December 23, 2009, 10:06:53 PM »
I emailed Tim and he recommends Nailbombs to cover a good range of rock tones. Can any one tell me how well they perform doing classic rock and more clean tones as most of the clips I've seen are modern metal.
Cheers for all the input
  • Brokeback is back
« Reply #11 on: December 25, 2009, 08:33:31 PM »
I find that my nailbomb bridge does cleans quite well, but like I said earlier in this thread I find it too agressive for more classic rock, but that's just my oppinion.
Stu
« Reply #12 on: December 27, 2009, 11:57:05 AM »
What would be the best choice if I wanted something slightly less aggressive than the Nailbomb in order for it to suit classic rock whilst still covering some heavy rock styles also?
« Reply #13 on: December 27, 2009, 03:53:55 PM »
The Nailbomb would be great.
The thing about the Nailbomb is that you can get such a great range of rock tones just by wonding down the volume control.
Mark.
dheim
  • DON'TPANIC!
« Reply #14 on: December 27, 2009, 04:46:56 PM »
i play metal, so mine is a metalhead biased view (;)) but i think that nailbomb should give you brilliant rock tones as well... don't forget that matt bellamy uses nailbombs too and he (wether you like muse or not) certainly doesn't play metal!
too many? ;)
