Soldering irons
Started by Ian Price, October 19, 2009, 04:14:23 PM
Hello all. Can anyone recommend a good soldering iron for general tinkering with guitars and effects. I'm not looking at spending huge amounts of money - probably up to £30.00ish.
Cheers in advance!
It's a fair bit more pricey, but this is the one I have.  I find the adjustable temperature very useful.
http://www.antex.co.uk/product.asp?strParents=&CAT_ID=180&P_ID=828
Dreichlift
I agree the TCS is nice, currently I use this one http://www.antex.co.uk/product.asp?strParents=&CAT_ID=180&P_ID=823, it's about £15 from rapid electronics I believe, good to get started with.
jibidy
I have an antex x25 or something like that.
I wouldn't worry to much they all do their job if you look after them.
Cheers guys - the B&D one looks like it might be the right one for me.
JDC
Quote from: Philly Q on October 19, 2009, 04:42:57 PM
useful for what? mine's some cheapo thing from B&Q, although now I'm thinking it was a rip off compared to MDVs swiss army soldering iron
Quote from: JDC on October 20, 2009, 01:43:53 PM
useful for what?
I put it on a high temperature for quickly soldering grounds, and a lower temperature for soldering connections to switches etc.  So you don't end up frying any parts or melting insulation all over the place.
ToneMonkey
I think there's a nice gas one for sale in Aldi this week  :D
i wouldnt get too excited about the 'swiss army' aspect of my soldering iron. The only things from it I use are the long needle-like iron tip and the stand. The arms broke off it almost instantly (but I have a proper metal set of extra hand croc clip things - very, very handy). Its a decent iron though.
I have a dremel gas soldering iron/blowtorch as well - its a psychopath; the heat from the vents on minimum setting wll strip cladding off any wire within an inch off them. Very good tool, but overkill for guitar electronics.
Quote from: MDV on October 20, 2009, 03:43:18 PM
I did wonder about those arms. I've got my eyes on a little gadget that has strong arms, heavy base and a big magnifying glass. Probably a good idea.
Quote from: Ian Price on October 20, 2009, 03:52:37 PM
I imagine its near identical to mine. They are very usefull.
jpfamps
Being able to control the temperature is useful if you are working with both leaded and non-leaded solder (RoHS compliant).
Non-leaded solder melts at a higher temperature than leaded solder.
If you can push the boat out I would go for a 25W iron minimum for soldering, especially if you intend to solder to pot cases. The 25W Antex looks a good buy. If you do a lot of soldering you will eventually wear out the tip so it is worth looking at the price of replacement tips too (if you can get them).
I would not recommend a gas solder iron.
The old adage "buy cheap, buy twice" is very true when buying tools......
