Author Topic: Neck Match for Ceramic NB?  (Read 2755 times)
toshiyao
« on: October 20, 2009, 05:06:34 AM »
Guitar is a Ibby Basswood. I wont be getting he calibrated version, so take that into consideration  :D
James C
Re: Neck Match for Ceramic NB?
« Reply #1 on: October 20, 2009, 06:01:29 AM »
the C-NB is basically an overwound cold sweat, so a CS neck would be a good option
Formerly "ManOnTheEdge"
toshiyao
« Reply #2 on: October 20, 2009, 07:06:54 AM »
I see, another thing is, the two pickups at the same height, any noticeable volume difference?
James C
« Reply #3 on: October 20, 2009, 07:56:23 AM »
for that you would have to ask Tim - I'd imagine there would be a slight drop, although maybe getting an Alnico bomb wound to match up with the C-NB might be a good idea, I have a set of Nailbombs in my vigier and the neck p/up delivers great cleans and leads.
Best piece of advice i can offer..........call or email Tim.
toshiyao
« Reply #4 on: October 20, 2009, 08:29:27 AM »
but I guess adjusting the neck pu higher will remedy that? I will giveh im an email. Thanks mate.
Benkenove
    • JOTNAR Official Website
« Reply #5 on: October 20, 2009, 12:10:27 PM »
Bad for you ;) I've got a C-NB calibrated set and works absolutly perfect... I wouldnt recomend anything else, this is simply perfect.
Nolly
  • Global Moderator
« Reply #6 on: October 20, 2009, 12:53:48 PM »
I personally love the Painkiller neck pickup, I have one in combination with a C-bomb in one of my main guitars and it sounds fantastic. Excellent match in terms of output too.
« Reply #7 on: October 20, 2009, 02:21:19 PM »
My c-bomb thats in a 2hb guitar is also paired with a painkiller. I second that. Works great.
(The other is with uber trilogies)
dheim
  • DON'TPANIC!
« Reply #8 on: October 20, 2009, 02:59:14 PM »
neck CS doesn't sound at all like a neck NB, and they're both A5, so maybe the "overwound CS" thing applies just to the bridge unit...
anyway if you don't want a neck NB (why on earth??), you could try a PK (ceramic, my favourite neck pickup for leads) or a neck MM, that's very versatile for cleans (i heard many say the exact opposite but i love my neck MM!)
my only basswood ibanez (an RGR) has got a couple of A5 warpigs but it flattens and darkens their tone a bit, compared with my other A5 equipped guitar, a mahogany epi LP... so maybe the PK should be the best option if coupled with a C-NB. not considering a neck NB, obviously...
too many? ;)
pagan7
« Reply #9 on: October 20, 2009, 09:53:43 PM »
I've recently fitted a calibrated set of c-bombs to a through neck mahogany Ibanez RGT. Tim said that he normally fits an alnico magnet in the neck pup of a calibrated set, but as they were replacing a set of a5-bombs on this guitar and I was looking for a little more tighness and high mids, so he fitted both bridge and neck pups with the same ceramic magnets used in the painkillers, and nickel allen head screw poles.
I haven't had much time free to fiddle with pup and pole screw heights to find the sweet spots for both yet, but initial impressions are that the neck c-bomb is rather too bright, even with treble rolled right back and a .047mf cap selected.
Plenty more playing around with them to do yet but I might revert to the standard soft iron slot headed screw poles and see if they warm the neck pup a little.
The bridge sounds superb btw - a tone half way between an a5-bomb and a painkiller - exactly what I was hoping for  :D
guitarxtc
« Reply #10 on: October 21, 2009, 10:38:59 AM »
i have ceramic nailbomb  bridge and alnico neck in my ibanez rgt3020 and is perfect set!
« Reply #11 on: October 21, 2009, 12:09:25 PM »
Thats not a bad way to describe it actually.
Glad you like it (the c-bomb is my favourite bridge pickup as well; it ousted the painkiller, which ousted the c-pig).
Dr. Vic
« Reply #12 on: October 21, 2009, 08:17:39 PM »
Lot of pups can be a good match with the C-NB actually.
What tone are you after and what amp are you using ?.
I'm asking that because I was thinking that If you don't want a calibrated set maybe you'd like to nail very different tones (from bridge to neck) while looking for maximum versality to cover different styles  :?:
asianaxeman
  • It's all about the Thrash!
« Reply #13 on: February 11, 2010, 12:43:32 AM »
which guitar did u haev this in? dya reckon it would work well in an alder ESP SV?
