Author Topic: nut cuttage (stop laughing!)  (Read 5459 times)
horsehead
« on: October 24, 2009, 09:33:37 PM »
OK so I'm fairly sure that the nut on my bitsa needs to be opened slightly as even the slightist movement on the trem result on it going out of tune, but I have never touched a nut ( I said stop laughing) because of the problems that come come with it, but I think that a slight opening of it would work.
Now comes the question!
I don't want to spend a fortune on the files, what can you guys (and gal) recommend please?
SG Thrasher
Re: nut cuttage (stop laughing!)
« Reply #1 on: October 24, 2009, 11:06:35 PM »
Have you tried some lubrication? Vaseline or...graphite from a pencil.
Laney, Charvel and BKP
Black covered Nailbomb that I want to trade for a Warpig/Riff Raff, PM me
horsehead
« Reply #2 on: October 25, 2009, 09:17:59 AM »
yep already in there...mixed some graphite into vaseline & put into the slots
« Reply #3 on: October 25, 2009, 12:11:31 PM »
Needle files aren't that expensive.
If the slot is big enough for a wound string, you can use that as a file too.
I've even done it with a nail file as long as it wasn't the high B or E.
If it's those high strings you might be able to do it with thin sandpaper.
« Last Edit: October 25, 2009, 12:13:12 PM by Ratrod »
horsehead
« Reply #4 on: March 04, 2010, 03:57:32 PM »
I need to do it on the b & E ironically. Anyone any ideas please?
« Reply #5 on: March 04, 2010, 08:48:02 PM »
We talking strat-bitsa, do we have a string tree as well?
If that's not lubricated yet, do that first (vaseline on a toothpick) - it might be the problem.
Otherwise what Ratrod said - thin sand-paper...
« Reply #6 on: March 04, 2010, 09:18:42 PM »
Piece of 320 or 600 grit wet and dry - folded in half and gently worked into the slot
Keep the paper angled so it is lower at the back of the slot than at the front
Add lube afterwards
