Author Topic: Straplock buttons too narrow gauge  (Read 2310 times)
fbloke
« on: October 27, 2009, 11:16:28 PM »
Folks,
I'm trying to fit straplocks to my Les Paul but they're thinner than the original strap button so don't tighten up to the body properly.  I've coated the screws in all-purpose strong adhesive and screwed them back in. I'm now waiting for it to set.
Is this a good idea?  Should I have packed the screw holes with something or do you think that the adhesive will hold?
Thanks,
Mike.
Re: Straplock buttons too narrow gauge
« Reply #1 on: October 27, 2009, 11:26:03 PM »
Matchsticks + a dab of wood glue into the hole.... provides something for the screw thread to bite on but can be unscrewed when needed.
You solution sounds quite a bit more permanent but how often do you change strap lock pins?  :?
Lew
« Reply #2 on: November 03, 2009, 01:33:43 AM »
Next time, just use the original screws in the guitar. It only takes a little work to make the hole in the actual straplock a bit wider to accept it.
« Reply #3 on: November 03, 2009, 10:47:11 AM »
Or use Dunlop straplocks which use a 1/8" screw - and fits the Gibson made hole somewhat better
