Author Topic: Neck companion for miracle man bridge.....  (Read 2725 times)
alendon
    • RED RIDING QUARTET / MYSPACE
« on: November 08, 2009, 10:45:00 PM »
Can anyone suggest a neck pickup that would go with my MM bridge?
I want something less full on than the miracle man neck....just a nice clear sound for cleans and a smooth overdrive that will keep up with the MM's output??
any suggestions folks ??
A5 pigs,A4 mules......red riding quartet
Re: Neck companion for miracle man bridge.....
« Reply #1 on: November 08, 2009, 11:16:23 PM »
Cold sweat.
« Reply #2 on: November 08, 2009, 11:19:56 PM »
Err what's wrong with getting a miracle man neck..... (well someone had to say it)  :?
If you hear it you will fall in love..
« Reply #3 on: November 08, 2009, 11:37:14 PM »
+1 on the Cold Sweat neck.
The MM neck is great though - and should also be tried as a BRIDGE pickup - works really great
Antag
« Reply #4 on: November 09, 2009, 11:17:58 AM »
Cold Sweat neck with a Miracle Man bridge is possibly one of the most popular combinations on the forum & the CS neck certainly matches the description "nice clear sound for cleans and a smooth overdrive that will keep up with the MM's output".
However the Miracle Man neck has IMHO one of the best neck lead sounds out there.  It's powerful, full & clear with that great "ooooo" vowel sound under drive.  The clean sound is very fulll & powerful, yet clear.  Because my favourite neck clean sound is the Holy Diver neck, a guitar with the MM neck is a bit much with the same amp settings.
Another good alternative is the VHII neck.  It is similar power to the CS, but has a slightly more "PAF"/vintagey vibe to the sound.  It has more of a "chime" to its clean sound & has almost a single-coil feel (albeit a very powerful one!) under gain.
alendon
« Reply #5 on: November 09, 2009, 12:57:04 PM »
Am I right in thinking the mm neck sounds like an emg 85???
DimeZakk
« Reply #6 on: November 09, 2009, 01:13:38 PM »
The MM neck sounds similiar to the 85, only much thicker, clearer and a little deeper. It is also pretty hot!
Antag
« Reply #7 on: November 09, 2009, 01:22:46 PM »
It doesn't so much sound like the 85, as it balances with the MM bridge in a similar way that an 85 neck balances with an 81 bridge, if that makes sense....
alendon
« Reply #8 on: November 09, 2009, 01:49:50 PM »
yeah that makes perfect sense. Think it could be narrowed down to the mm or cs....but most likely the mm......: )
Antag
« Reply #9 on: November 09, 2009, 02:02:49 PM »
FWIW, I made some clips a while back:
Clean shootout
CS & MM in a Clean+Lead shootout
alendon
« Reply #10 on: November 09, 2009, 04:40:01 PM »
Cheers for that .I'll give em a listen.
alendon
« Reply #11 on: November 11, 2009, 12:53:23 AM »
Well it's a close call but I think its going to be the MM neck for me.sounds a lot fuller and less hollow than the CS to my ears anyway...
Thanks everyone for your advice and knowledge.
Adrian :P
« Last Edit: November 22, 2009, 10:35:33 PM by alendon »
