Poll
What's the best type of cab for pub gigs playing standard rock covers
4x12
1 (5.9%)
2x12 open back
9 (52.9%)
2x12 closed back
5 (29.4%)
Other (please state)
2 (11.8%)
Total Members Voted: 16
Author Topic: 4x12 vs 2x12 for pub gigs  (Read 10615 times)
Dazza1004
« on: November 11, 2009, 08:47:16 AM »
I’ve got an Orange 2x12 which although I like, it’s pretty directional, I can’t help thinking I would be better off with an open back 2x12 for the standard rock tunes / pub gig.
I was looking at the Bogner oversized open back 2x12 but they don’t seem to be much smaller than a 4x12. On one hand I think a 4x12 will be overkill for the pub and may still be directional, on the other hand I’ve had one so not sure if it would be a better option (although I think moving it around would get old, quick).
I've got a 5150III head but looking to change for a Bogner XTC soon.
Cheers
Re: 4x12 vs 2x12 for pub gigs
« Reply #1 on: November 11, 2009, 08:50:49 AM »
I would use two ported 1x12s. My Mesa Boogie Theiles are less directional than a 4x12
martinw
  • Building Amps in the Hills.
    • http://www.mjwamps.com
« Reply #2 on: November 11, 2009, 09:38:23 AM »
Open backed 4x10 for me.
1x12 in smaller places. :)
Custom Built Amps:
www.mjwamps.com
« Reply #3 on: November 11, 2009, 09:38:51 AM »
I use both with different bands, so here's my take:
AC/DC tribute - I'm Angus and need the spread, punch and cut of a 4x12.  I need to be the loudest guitar at all times, so a half stack is by far my preferred option.  I've gigged with a 2x12 and got away with it, but the 4x12 is SO much better for oomph and projection.
Rock covers - it's a two guitar setup with shared lead and rhythm parts.  Balance is important, as is keeping the overall volume manageable.  I wouldn't use anything bigger than a 2x12.  Martin (from MJW amps) is the other guitarist and he uses a 4x10 or occasionally a 1x12.
As a side note, my 2x12 is semi-open back and works fantastically well in all situations and has plenty of low end etc......
EDIT:  Spooky crossed post!
« Last Edit: November 11, 2009, 09:41:52 AM by Twinfan »
Dazza1004
« Reply #4 on: November 11, 2009, 09:48:51 AM »
Is it an MJW ?
« Reply #5 on: November 11, 2009, 09:57:45 AM »
Yup  :)
mikeluke
« Reply #6 on: November 11, 2009, 11:01:23 AM »
Hope he does you a good deal!
Mules, Riff-Raff
« Reply #7 on: November 11, 2009, 11:46:56 AM »
I use a '67 Bandmaster cab. 2X12 'ventilated' closed back with Jensen C12N's. It's wide and shallow.
One of the best cabs ever made IMO.
A 4X12 is often overkill.
Dazza1004
« Reply #8 on: November 11, 2009, 01:07:21 PM »
I suppose if I get a bit of wood the same dimensions as the back panel of my Orange I could cut a hole in it and have an interchangeable open / closed 2x12
anyone ever try something similar ?
  • Truly bad since 1972
« Reply #9 on: November 11, 2009, 01:29:37 PM »
helped convert a matamp to open back(4x12) sounds great
blue
« Reply #10 on: November 11, 2009, 01:34:03 PM »
my Vintage Modern is closed back, but i would have thought just unscrewing the back panel would basically make it open.  can i take it from the above posts about conversion that this would not be an entirely good idea?
psy
    • Me singing & guitaring
« Reply #11 on: November 11, 2009, 01:49:38 PM »
I've got a Zilla 2x12" cab that's interchangeable open/closed (because I wasn't sure what I wanted when I ordered it).  Quite handy, the back is made up from three parts with the connections on the top part.  That leaves me the option to remove the middle & bottom part.  I currently have the middle section removed as I find the sound fills the room better than it was closed.
Dazza1004
« Reply #12 on: November 11, 2009, 01:51:54 PM »
That's the sort of thing I was thinking of, I don't want the back to be completely open, just a couple of inches in the middle to help spread the sound around.
« Reply #13 on: November 11, 2009, 02:15:58 PM »
That's exactly how my 2x12 is set up....
psy
« Reply #14 on: November 11, 2009, 02:41:19 PM »
Yeah, it's the best of both worlds.  I'd go for it.. and if you don't like it you can just close the gap.
