Help me,please. Nailnomb or Missisipi Queen
Started by tomm, November 11, 2009, 02:28:27 PM
tomm
hi everybody,
i want help to choose one of this two pickups.i want a  bridge p.u. that can gives me a raw distorted sound (ala white stripes,queen of the stone age,RATM) but that i can split,and have a clean twangy sound.Can a mississipi queen gives me a strong overdrived tone(can i be able to make good pitch harmonics,or harmonics behind the nut) or can a nailbomb gives me a clean twangy sound(i can split it too),and be not too metal when i overdrived it?
sorry for my very bad english.
my guitar is a schecter pt (ash bosy,25,5 scale lenght,split coil)
amp: fender deluxe reverb,or engl  screamer 50w
Thank you
Hi  :)
I think you would like a Mississippi Queen with a coil 'tap'.  You would use the full pickup for heavy overdrive sounds, then use the tap (basically a weaker version of the same pickup) for your cleaner sounds.
I think that would be great!
tomm
thank you for the replay...so do you think that the MQ is hot enough to give me  rude and heavy(but not metal) distorsion?
I got a semi hollow 335 style guitar with Mississippi Queens in and it produces some nice distortion. You can check out the following thread to get a sound sample. http://bareknucklepickups.co.uk/forum/index.php?topic=18151.0
tomm
thank u..you have a nailbob too,aren't you?...what are the major differences when it is distorted?can you do pitch harmonics with a missisipi queen?can it make a thick distortion?
The Mississippi Queen can get VERY thick if you want it to, and rude  :)  Mine certainly was!
I haven't owned one, but I would imagine the Nailbomb would be smoother?
badgermark
I can get pinched harmonics and a fat sleezy distorted sound out of my tele with mississippi queens. That's using a crunchbox distortion pedal and my tiny terror mind. It sounds massive.
Quote from: tomm on November 11, 2009, 08:30:35 PM
I got a nailbomb too that's correct, but I haven't had it for that long and haven't played it much so I can't really comment on it. Sorry.  :(
tomm
Quote from: badgermark on November 11, 2009, 11:10:24 PM
Thank u...do you have some samples ?What type of tele do u have?
badgermark
Quote from: tomm on November 12, 2009, 11:06:00 AM
No samples right now and it's in a 72 telecaster deluxe RI. Alder body and maple neck. I love the MQs so much I'm very tempted to swap my other set in my les paul into my SG.
badgermark
Quote from: Mr. Air on November 12, 2009, 07:31:12 PM
Hey Mark
How are the MQs in a Les Paul?
funny you should ask, I've just finished moving them from my LP into my SG. They sounded huge in the les paul, very balanced but thick.
tomm
last question...can you tell,if you know, what are the major differents between mq and a seymour duncan jb(sh-4)?
dheim
Quote from: tomm on November 12, 2009, 09:04:22 PM
well, the jb is an humbucker, the MQ is an oversized single coil, so they're completely different in every aspect! think of three stratocasters playing together and you'll get an idea... :) warmer and bigger than a single coil, it can handle really raw distortions as well as bluesy saturated tones and sparkling cleans.
the Nailbomb is much more similar to the JB, but it sounds a lot richer... hi-mids are more pronounced and the lead tone is the best i've ever heard in my life. it's hard to explain exactly why, but if you are a lead guitarist you can hardly get a better tone. expressive, dynamic, singing in the most literal way, bright but deep at the same time. it sounds like a JB put off the wooden box it was trapped into.
a great set could be NB bridge + MQ neck.
Muse's frontman Bellamy uses it on most guitars, and even if you don't like Muse it's very versatile and surely will give you a wide range of great rock tones. even if you don't push yourself into those metal territories Nailbomb belongs...
too many? ;)
tomm
[/quote]
great answer...but i want put a fernandes sustainer in the neck(yes,i'm matt bellamy fan too lol)...so i can't really choose between the mq and the nailbomb
