NAD - a new HTH AMP is born...
Started by HTH AMPS, November 12, 2009, 08:12:40 PM
Quote from: FELINEGUITARS on November 13, 2009, 10:59:18 AM
Cool
I just got hold of a reverb pedal which I had been wanting before making video clips with my HTH 10W SE amp
So hopefully I will now get a chance to make some clips
good to hear, can't wait to hear your clips.
roland_rat
Cool,
Will be good hearing some more clips of another HTH amp.  What reverb pedal did you get Johnathan?
Quote from: MDV on November 12, 2009, 09:39:47 PM
Quote from: HEAVIER THAN HELL on November 12, 2009, 09:30:32 PM
Quote from: MDV on November 12, 2009, 08:39:59 PM
Sounds really cool. Thats a lot of grind in there.
Is this the amp we talked about last year? Could you knock up a full on detuned metal clip please?
no, its not that amp, this is FAR more polite than that amp will be.
this amp has four gain stages whereas yours will have between 6 and 8 gain stages and make this amp look like a country and western affair (i.e. serious br00talz!!!)
will see what I can knock up in the way of extreme metal goodness for you Mark.
Sweeeeeet.
here's some Carcass for you...
http://www.youtube.com/watch?v=eV1Dzmbn0Lg
Quote from: roland_rat on November 13, 2009, 01:07:50 PM
Cool,
I got a Lee Jackson Mr Springy!
It's pretty simple but has a great sound - have to set it low or it gets all rockabilly on you
Clip here shows it off well
http://www.youtube.com/watch?v=TK6PTtzKnbA
gingataff
I see a rainbow rising
Look there on the horizon
And I'm coming home
Quote from: HEAVIER THAN HELL on November 13, 2009, 10:46:08 AM
it is and it isn't - 'modded epi' implies that the circuit has been tweaked, however in relality the chassis was stripped bare and the only things used from the EVJ are the mains transformer, speaker output jacks, IEC mains socket, the chassis and head cabinet.  the actual circuit bares no resemblance to the Epi circuit.
however, I am looking at a way of incorporating this circuit into an EVJ and still using the existing PCB, but adding an extra ECC83 and of course gain, b/m/t, and master controls.  should keep it more affordable for those who don't want a scratch build and might have an EVJ that isn't doing the business.
thanks. yeah, i figured it wasn't too close the the VJ, what with the 4 gain stages and all. i just meant the headshell, though that wasn't clear from how i worded it... :lol:
Quote from: HEAVIER THAN HELL on November 13, 2009, 01:30:18 PM
Sweeeeeet.
That slays, I like it!
That sounds well good HTH, all the clips, nice one :D
Sounds great man, congrats.
Bit more body in the tone would be the only thing I'd like, but that can be the cam/mic.
Quote from: hunter on November 17, 2009, 08:53:09 AM
cheers Hunter.  it sounds better in person and has plenty of body.  might be your PC's speakers too - my laptop makes everything sound cr@p, but my desktop PC isn't too bad at all.
Catalyst77
Ok
I just took this to band practice and flat out it is just loud enough to live with my heavy handed megadeth loving drummer, which is totally insane for a 5 watt amp.  Its as lound as my 50watt orion with the volume at 3 o'clock! :o
mikey5
Dude I really like the 10 watt marshall thing you should do a mini cranked JCM 800 some day
Quote from: Catalyst77 on December 01, 2009, 10:54:50 PM
Ok
glad to hear it  :lol:  8)
Quote from: mikey5 on December 02, 2009, 03:40:44 AM
the 10w amp is pretty close to a JCM800, just hotrodded for more gain.
a JCM800 in a 10w, 5w, 1w or whatever you want is possible.  actually, I did make a 1w JCM800 that sounded great, but I've since wired it up for something else as it was my experimental amp chassis.
