Author Topic: NAD - a new HTH AMP is born...  (Read 6792 times)
« on: November 12, 2009, 08:12:40 PM »
I've recorded four clips of this new amp, here's one to get you started - should be able to find the others easy enough...
http://www.youtube.com/user/TeleCustom72#p/u/2/jlizxRajonQ
I'm really happy with the way this one has turned out, really fat tone with enough gain to cover 60s rock/blues through to fairly heavy rock/metal.
These were all 1st take run throughs, so there are mistakes - its more about the amp's tone though, not my playing.
EDIT: btw, since this is the BKP forum, you will be glad to know that a BKP Axraxas set were used for these clips (unless noted otherwise).
Re: NAD - a new HTH AMP is born...
« Reply #1 on: November 12, 2009, 08:39:59 PM »
Sounds really cool. Thats a lot of grind in there.
Is this the amp we talked about last year? Could you knock up a full on detuned metal clip please?
« Reply #2 on: November 12, 2009, 08:45:53 PM »
Sounds damn good, specially the AC/DC and ZZ Top clip
Catalyst77
« Reply #3 on: November 12, 2009, 08:53:57 PM »
Dude you've stolen my new amp day thunder! :o
roland_rat
« Reply #4 on: November 12, 2009, 09:08:27 PM »
Very nice. What valves have you got in this little amp?
« Reply #5 on: November 12, 2009, 09:14:32 PM »
I know, sorry Ben - I couldn't wait.  You should record some clips too when it gets to you next week.
« Reply #6 on: November 12, 2009, 09:18:55 PM »
+1 some technical infos would be very nice! no one could argue with the tone in those clips
« Reply #7 on: November 12, 2009, 09:30:32 PM »
no, its not that amp, this is FAR more polite than that amp will be.
this amp has four gain stages whereas yours will have between 6 and 8 gain stages and make this amp look like a country and western affair (i.e. serious br00talz!!!)
will see what I can knock up in the way of extreme metal goodness for you Mark.
« Reply #8 on: November 12, 2009, 09:30:57 PM »
two 12AX7s and a 6V6
« Reply #9 on: November 12, 2009, 09:39:47 PM »
Sweeeeeet.
  • Truly bad since 1972
« Reply #10 on: November 12, 2009, 09:50:50 PM »
nice so is converted epi
« Reply #11 on: November 12, 2009, 10:54:17 PM »
sweet, is that a modded VJ? Listening to the VH clips, very nice indeed.
« Reply #12 on: November 12, 2009, 11:00:13 PM »
Extremely funky.
« Reply #13 on: November 13, 2009, 10:46:08 AM »
it is and it isn't - 'modded epi' implies that the circuit has been tweaked, however in relality the chassis was stripped bare and the only things used from the EVJ are the mains transformer, speaker output jacks, IEC mains socket, the chassis and head cabinet.  the actual circuit bares no resemblance to the Epi circuit.
however, I am looking at a way of incorporating this circuit into an EVJ and still using the existing PCB, but adding an extra ECC83 and of course gain, b/m/t, and master controls.  should keep it more affordable for those who don't want a scratch build and might have an EVJ that isn't doing the business.
« Reply #14 on: November 13, 2009, 10:59:18 AM »
Cool
I just got hold of a reverb pedal which I had been wanting before making video clips with my HTH 10W SE amp
So hopefully I will now get a chance to make some clips
