Holy Diver: too much hights?
Started by case report, November 26, 2009, 08:38:18 AM
case report
Hi everybody
this is my first message, I'm glad to be in this wonderful community!
I have a Jackson guitar Fusion Professional (1991), HSS, basswood body, maple neck, ebony fingerboard, Floyd Rose, 10-46 strings, standard tune, and I usually play Maiden, Skid Row, Van Halen, Scorpions and something more modern like Creed/Alter bridge...
I'd like to change the original humbucker with Holy Diver but I have a doubt:
does the basswood overemphasizes mids and high end?
Could be the Nailbomb more equilibrate?
I like full and huge sound...
Please help  :lol:
Gibson Les Paul Historic 1958 - Stormy Monday
Charvel San Dimas - Holydiver (b) -Crawler (n)
Jackson Fusion Pro - Holydiver & Trilogy Suites
No, all things being equal basswood is pretty linear.
You should get on pretty well with a holy diver.
dheim
Quote from: MDV on November 26, 2009, 09:03:15 AM
+1
i'd add that basswood is quite on the dark side, but the HD should work well, expecially if you want it to sound HUGE! :)
too many? ;)
case report
Thank you so so much for your very useful opinions!
Now I'm pretty sure that I'll get a Holy Diver  :x
In the warmoth link by hunter, basswood seems to be warmer than alder... I didn't know it!!!
Maybe the Nailbomb is best on Les Paul, isn't it?
The Sorbz
I have a Warmoth Soloist which I had a Holy Diver in.  It sounded great and very, very expressive.
Ta,
Jim
[url="//www.soundcloud.com/Jim-Sorbie"]www.soundcloud.com/Jim-Sorbie[/url]
case report
Quote from: The Sorbz on November 27, 2009, 12:23:36 PM
Ta,
Jim
Interesting... Basswood body?
C.R.
Antag
OK, I have Holy Divers in 6 guitars (actually 8, but 2 of those are the old-spec ceramic HD):
Korina body, bolt-on Maple neck, Ebony fretboard
(2) Maple thru-neck w/Alder body wings, Rosewood fretboard
Maple thru-neck w/Alder body wings, Ebony fretboard
Mahogany thru-neck w/Mahogany body wings (+ laminate maple top), Ebony fretboard
Mahogany body w/carved Maple top, set Mahogany neck, Rosewood fretboard
In my Korina strat, which is probably closest construction-wise to yours (Korina is "warmer" than basswood), it sounds absolutely MASSIVE with bucketloads of thick raunchy midrange grind.  I recorded a rough clip with it a few years ago here
Compare it with a clip I recorded on my Jackson RR1T (Maple thru-neck w/Alder body wings, Ebony fretboard) at about the same time using the same amp here
I think HD is the best choice for what you want.   You certainly won't find it too bright or lacking in "body".
BigB
case report
Thanx Antag, you rock!
Holy Diver will be mine!
do you think it's unnecessary buying the complete set (+ Irish Tour single coil)?
maybe the neck pu only? (I don't use the middle pu)
I know that the complete set is the best but money misses  :(
Quote from: Antag on November 27, 2009, 02:04:40 PM
Antag
Quote from: case report on November 27, 2009, 07:42:48 PM
It's entirely up to you.  If you never use the middle & neck pickups then there's no real point.  You can always buy them later if you change your mind (although getting the HSS set saves you £18 over buying them separately).
I have the HD/IT HSS set in my Korina strat & like it.  The ITs have a real "pop" to them & a lot of top end sizzle that contrasts nicely with the meaty bridge pickup.  There are some really nice sounds in there (hint: don't coil-split the bridge in position #2 - the Bridge Hum + Middle single is beautiful)
Note that all the BKP single coils are "real" single coils, not hum-cancelling stacked or rails pickups.  Also note that they require the standard single coil rout (like the neck pickup on this), not the EMG-style straight rout (like the middle pickup on this) - depending on the pickups in your fusion (got a pic of it?) they might not fit.
case report
Quote from: Antag on November 27, 2009, 08:12:47 PM
Antag, precious informations!
my fusion pro is similar to that:
http://www.jcfonline.com/gallery/jack-strats-pics/F901247.jpg
Isn't possible to mount BN Irish Tour?
Antag
Quote from: case report on November 28, 2009, 05:07:43 PM
You'll need to contact BKP & ask - they used to offer single coils for the EMG rout as a special order, then they stopped.  If there's been enough demand maybe they started again? Best to ask directly...
EIther way, the standard SC won't fit in that rout.  It's fairly straightforward to get a decent Luthier to rout out the extra bit for a "lip" - Feline did my Charvel & it didn't cost much IIRC...
Quote from: case report on November 26, 2009, 08:38:18 AM
with those bands, I would immediately think Cold Sweat.
IntenseJim
Quote from: HEAVIER THAN HELL on November 28, 2009, 10:09:30 PM
I love those tones but I found the Cold Sweat (CS) too bright for me with not enough mids.
Just straight line it !
