What type of BKP?
Started by fatbob, November 15, 2005, 11:32:58 AM
fatbob
What would sound similar, tone & balance wise, but with less compression (output?) to the stock "Duncan/Ibanez" pickups in my Ibanez SZ320? I love the sound of this guitar, which I only got last week, but it overdrives my amps (Laney LC15R & Marshall VS275) a little early, rendering the top 1/3rd of each gain control redundant! The pickups would need to be coil-tappable for the middle position on the 3 way.
Currently abusing Ibanez, Conklin & Hohner guitars & basses Laney, Marshall, Ashdown & Hartke amps
HJM
What do you like about the tone - bright/dark/midrange....that kind of thing?
fatbob
The basic tonal balance is very neutral, solid bass, smooth mids and detailed but smooth top end. Being critical, the neck pickup is maybe too bassy, but it is still clear. Does a nice Gary Moore tone. The output is balanced well between the pickups, but just a bit too hot.
HJM
You could go as low as a mule, or perhaps a VHII or Abraxas. WHat's the DC on the pickups?
fatbob
bridge is a ceramic based on duncan distortion @ 17.4, neck is based on a '59 @8.5.
Crawlers maybe? They are around 14k arent they?
HJM
You could try a cold sweat bridge, the new on sounds great, not as high output as your Duncan, but it's ceramic and sounds fat!
^aren't nailbombs hotter than what he has already?
EDIT: although with an alnico V mag, they might not be- they should be more organic, anyway...
fatbob
I take it if in the calibrated sets, the neck has a lower dc than the specs quoted for the individual pickups?
Quote from: fatbobI take it if in the calibrated sets, the neck has a lower dc than the specs quoted for the individual pickups?
Yep!
fatbob
Listening to the sound clips, the two that sound best to me are the mule and vh11. Which would suit my guitar best, bearing in mind i dont like an over bright sound.
i don't know much about the eq of either pickup (i haven't tried them)
but maybe vh2 bridge, mule neck (for a slightly hotter bridge pickup)?
both should soun dkind of warm, i'd have thought
anyway, you're used to a pretty high output bridge pickup, just watch you don't go overboard to one that's not hot enough!
The VHII is a bit on the trebly side. The Mule is much warmer.
fatbob
Thanks for all the advice, I've taken the plunge and ordered a set of Black Dogs, seem like the best option, being a "hot PAF" and being a huge fan of Alex Lifeson myself! Now for the  ham fisted installation....
