Author Topic: I've just ordered...  (Read 4469 times)
bucketshred
  • Groovy
« on: December 07, 2009, 11:28:20 PM »
a Warpig for my SG.
Going to stick my Miracle Man in my Explorer soon too. Anyone know if a 53mm pickup will have problems in a 50mm guitar?
Paddy.
GREAT GOOGILY MOOGILY!
Re: I've just ordered...
« Reply #1 on: December 07, 2009, 11:35:14 PM »
Nah, you'll be fine.
Did you get the leg length right?  Youll need a long leg pickup for an SG Standard or Special, short legs for a '61 reissue.......
« Reply #2 on: December 07, 2009, 11:44:10 PM »
I've got a 53mm Riff Raff in my SG-X.  The spacing's a little too wide, but the 50mm is a little too narrow - not worth worrying about the difference really.
bucketshred
  • Groovy
« Reply #3 on: December 08, 2009, 12:05:28 AM »
Well i got a 50mm Warpig for the SG. Long leg.
Paddy.
mijat
« Reply #4 on: December 11, 2009, 06:00:35 PM »
I've just ordered a Miracle man for bridge and a Cold Sweat for the neck. :violin1:
Antag
« Reply #5 on: December 12, 2009, 07:30:07 AM »
I've found that a large number of my guitars seem to have 51.5mm spacing between the strings - i.e. bang in the middle :roll:
Either pickup spacing works - even if the top & bottom strings only just line up with the edge of the pole piece, they're well within the magnetic field.  If in doubt, go wider.
« Reply #6 on: December 12, 2009, 12:00:08 PM »
Yeah, I find DiMarzio's F-spacing is actually the best fit on most guitars (that's not meant as a DiMarzio sales pitch!).
skaniels
« Reply #7 on: December 17, 2009, 09:44:01 PM »
Did you recieve your pickup yet? I ordered my Mule set December, 5th.. still waiting patiencely..
« Reply #8 on: December 17, 2009, 10:09:56 PM »
real gibson spacing for the bridge position is 52mm
all their bridge pickups I've seen were 52mm
« Reply #9 on: December 17, 2009, 10:18:24 PM »
That's just the "modern" ones like 490T, 498T, 500T.  The "vintage" ones like '57 Classics, Burstbuckers etc are closer to 50mm.
« Reply #10 on: December 18, 2009, 01:05:51 AM »
do they use different bridges for each model?
cause I've never seen a gibson/schaller/gotoh bridge with 50mm
and I actually did a lot of searching
even my '73 les paul custom has a huge schaller harmonica bridge that came in all SG models, les paul recording and the les paul signature, and I always though that bridge was 50mm, but it's actually about 52mm and the string spacing is much wider than the regular spacing of my nailbomb
« Reply #11 on: December 18, 2009, 09:50:49 AM »
They use either an ABR-1 or a Nashville on everything, so I agree, the spacing at the bridge itself is always more like 52mm.  They do notch the saddles by hand and sometimes they're centred, sometimes they deliberately seem to go a bit wider.
I haven't had my hands on many real vintage Gibsons, maybe the saddles were spaced a little narrower in those days?  Or maybe the strings always sat towards the outer edges of the bridge-pickup polepieces.  :?
mijat
« Reply #12 on: December 18, 2009, 07:56:56 PM »
I've been notified of credit card payment via email today.. So I guess it will be around 10-15 days more.. :(
GODDAAAAMN this waiting is the worst thing  :x
 :D
