Quote from: blue on December 11, 2009, 12:09:37 PM
sorry to hijack, :)
can you simply substitute a KT66 or KT77 with EL34's? that is, if your amp has one you can just put in the other, (with a rebias of course) with no modifications? if so, does that mean EL34's will work in a Marshall Vintage Modern? and likewise, an EL34 Marshall will accept KT valves?
All the common 8-pin power valves have the same pinout (more or less) so they can be often substituted in amps are long as:
1) There is enough heater current capability in the power transformer: EL34s require 1.4 A per valve compared to 6L6s which draw 0.9 A, so in an amp designed to use EL34s 6L6s won't stress the filament supply, but the converse isn't always the case.
2) There is enough range in the bias supply to allow the valves to be biased correctly. 6L6s require a more negative bias voltage than EL34s for example.
3) EL34s need pin 1 and 8 tied together for correct operation. Amps designed for 6L6s may not have this connection.
4) There may be issues with screen current draw when swapping EL34s into an amp designed for 6L6s if the screen grid resistors are the typical 470 ohm used with 6L6s.
5) The voltage compliance of the valves is not exceeded. For example the screen voltage rating of 6L6s is lower than EL34s.
The KT77 should work in any amp designed for EL34s as it is effectively a beam tetrode equivalent. KT66s would probably require that the bias supply is modified.
Obviously in an amp that can accomodate 6L6s and EL34s you should be able to use KT66s, KT77s, 6L6s and EL34s.
It's quite interesting trying different valves in the same circuit, however you do need to bear in mind that often a certain circuit is optimized for a certain valve (e.g. drive voltage, feedback factor, plate impedance), so if you say try some 6L6s in a Marshall and you don't like the results, it could be that those valves don't work for you in that circuit rather than they are inherently "bad" valves.
This is the caveat I would apply to the JJ-KT77s, ie we weren't overwhelmed by their sound in the circuits we were using (although we were trying to design the amp around the KT77!!), however they may well be very good in other circuits.
