Author Topic: Question, installing my first BK pups!  (Read 1484 times)
Chris Swollenballs
« on: December 14, 2009, 09:22:18 PM »
Not my first pair but this will be the first time I'm doing it on my own.
With Tim's help, this seems easy as heck.
I have a 40 watt soldering iron and I've been told the standard is 60/40 lead free rosin core solder.
Couldn't find any so I got a few different sizes and they're all lead free rosin core, it doesn't have to be 60/40 right?
Lucifuge
Re: Question, installing my first BK pups!
« Reply #1 on: December 14, 2009, 09:37:11 PM »
I don't think you will find 60/40 lead free - the 60/40 is 60% tin and 40% lead, while the lead free has a much higher percentage of tin; 99% or so AFAIK.
I'd say the 60/40 with lead is a better bet, as the lead-free has a higher melting point so needs more heating, causing a greater chance of overheating the pots or something.
I'm sure someone else will correct me if this is wrong.
Chris Swollenballs
« Reply #2 on: December 14, 2009, 10:37:58 PM »
Ah!
Gotcha.
I'm currently using a Weller 40 watt soldering iron that operates around 900F.
This is the solder I purchased:
http://www.bernzomatic.com/PRODUCTS/SOLDERANDACCESSORIES/ELECTRICALSOLDER/tabid/253/ctl/Detail/mid/1261/xmid/6905/xmfid/3/Default.aspx
It's lead free but it melts at 430 F.
Is that fine?
BigB
  • Let's rock !
« Reply #3 on: December 15, 2009, 02:19:22 PM »
FWIW, I bought the cheapest 40W soldering iron and the only kind of solder (don't even ask me if it's lead-free or whatever) I could get at the local store, and it works just fine.
