Author Topic: floyd rose tuning annoyance  (Read 4572 times)
Stevepage
« on: December 16, 2009, 11:35:05 AM »
Right so, on my Carvin, I've recently noticed that when I have the trem floating, it doesn't stay in tune all that well.
When I block it using the Tremol-no installed in the guitar, it's fine. Though still some problems.
I've stretched the strings, set it up properly, changed the nut to a gotoh nut about a year ago (old one cut into to strings). Could there be a problem with the knife edges or mounting studs?
What's the best way to know? and how should I go about getting it sorted?
Re: floyd rose tuning annoyance
« Reply #1 on: December 16, 2009, 12:46:57 PM »
It could be anything.
Pinching nut, the trem pivots, spring adjustment, saddles, lubing etc.
You might want to take it to a good tech.
Oli
« Reply #2 on: December 16, 2009, 10:21:25 PM »
Have a look at the knife edges, and check for signs of wear, and also make sure that the edges and studs are cleaned an lightly lubricated.
