Author Topic: How many coats of tru oil for a neck?  (Read 12552 times)
tomjackson
« on: January 04, 2010, 02:59:23 PM »
I've done 3, looks okay but should I do a few more?
Cheers
Tom
Re: How many coats of tru oil for a neck?
« Reply #1 on: January 04, 2010, 03:13:57 PM »
I did 3 (I think!) on mine, and it was fine.  Wez said so, so it must be true!
« Reply #2 on: January 04, 2010, 03:38:27 PM »
Good question and it depends on the kind of finish that you want ad whether you used Wire wool between each coat to knock it back
I will often do as many as 20+ coats but knock the finish back afetr every couple with 0000 grade wire wool
the last 3 or 4 coats will be left for several days or longer before smoothing back to allow it to really harden up
tomjackson
« Reply #3 on: January 04, 2010, 04:06:58 PM »
Thanks fellas!
Yes Feline I sand back after every coat with Liberon 0000.  I think I'll do it every other for a few more coats then leave a couple to harden at the and as you say.
I don't know what finish I'm after, thin but durable I guess.
Dave, have you had any signs of playing wear from the 3 coats on your neck?  I think I'll end up with about 10 in total.
« Reply #4 on: January 04, 2010, 05:49:04 PM »
Slightly off-topic, but on a body, would you still use wire wool?  Or would you use wet/dry paper on a sanding block to keep the finish flat?
« Reply #5 on: January 04, 2010, 06:22:00 PM »
Nope, but then it's not had serious use.  I just wanted it sealing so it still felt like raw maple - not a 'finish' as such.
« Reply #6 on: January 04, 2010, 06:41:13 PM »
3 coats and a rub back is a light oil finish and will show signs of playing wear eventually and may also need a little more mainetnance to keep it feeling nice, just the occasional re-oil and rub down.. its as raw a maple neck as i do.  10 coats of tru-oil is much more like a full finish
tomjackson
« Reply #7 on: January 04, 2010, 08:39:06 PM »
I used wire wool on mine, the finish should already be flat enough before you start using wire wool.  the 0000 grade is more of a polisher than a sander so if the finish is already flat I don't think the wire wool would change that.
the finish on my swamp ash Tele body is pretty raw and open grained though
« Reply #8 on: January 04, 2010, 08:43:44 PM »
oh, yeah.  i would wire wool the body too.   what tom says is spot on
for an example here is Roo's guitars with about 6 coats of tru oil going over bubinga, maple and wenge and polished out with the liberon wire wool
« Reply #9 on: January 04, 2010, 08:54:14 PM »
Thanks gents!  :D
