Over Christmas I went back to the UK and decided to give my old Laney AOR 3012 combo (Series I AFAIK) a bit of an overhaul.
I only get to play it once a year but I noticed a while back that the sound was becoming intermittent as well as some nasty clipping on the High input.
I replaced all the valves with some JJs and replaced most of the electrolytic caps too (a JJ 50/50, some Nichicon MUSE and F&Ts for the rest. The only ones I didn't change were the caps in the bias circuit and the small 2.2uf caps) and the problems were just the same.
I made some recordings of the amp, apologies for the low quality!
First is the clip showing the intermittent sound. Interestingly when I jump the FX loop with a patch cable it's fine.
http://www.youtube.com/watch?v=SQ3eecc_I1QSecondly I made a recording where I change from High to Low input and you can hear the clipping. It sounds to me like something in the input is being overloaded. It's a lot more annoying in real life than on these clips I can assure you.
http://www.youtube.com/watch?v=iu6CbOSGXAUAnyone have any ideas? I probably won't be able to test it again until the end of this year so there's no rush ;)
