Main Menu
DIY cables
Started by MrBump, January 23, 2010, 05:55:28 PM
I think that I might make some cables for a new pedal board that I'm planning.
Does anyone else do this?  If so, where do you source your cable and jacks?
Mark.
gingataff
#1
I do it but I'm fairly lucky that I live about 30 minutes away from some shops that specialise in cables and plugs. I'm sure there must be plenty of online options though.
The best advice I can give is that I find Switchcraft jacks easiest to solder to though they aren't cheap, and you should take care not to melt through the jacket of the cable when you crimp the end of the plug.
Oh, and don't forget:
Put the barrel of the plug on the cable before you start soldering
It's worth getting some heatshrink tubing too.
I see a rainbow rising
Look there on the horizon
And I'm coming home
andymac
Studiospares have a good choice of cables and plugs.
Andy
2 Les Pauls 1 Mule Bridge 1 Black Dog Bridge.  Feline Lion 2 Crawlers, Tele - Piledriver Bridge and Boss Neck
psy
Yeah, the last lot of cables I made up (they were mic cables, but more or less the same thing) I got my parts from Studiospares.  I used Neutrik hardware, they seemed really well made.
Thanks guys - looks like studiospares is the place to go.
Mark.
Keven
i second neutrik hardware. as far as cable goes, i red the George L's were really well made.
My BK's:
C-Bomb Set / Blackhawk Bridge
Holydiver Set/ BG50 Set
Oli
At work (commercial recording studio), for instrument cables, we use VDC (Van Damme) cable, with Neutrick connectors... nice and easy to make up, and very durable :)
